Moving to California. The 76 would have to be emission tested. The car is in eastern Iowa right now. The car is completely drivable and road worthy. The only thing it really needs is paint and to be detailed out or finished to your own taste.here is what I've done so far:
Engine; 2000 5.3 LS family out of a chevy truck, LS6 intake, cold air intake, headers
Interior; New carpet, 1982 Corvette seats, 1982 Corvette tilt-telescopic wheel, various new parts, Original seats included
Drive train; Transgo shift kit in transmission, 2500 rpm stall torque converter, Rear end rebuilt w/ new hardened stub axles
Wheels & Tires; 18x8 Wheel Replica IROC wheels, 255-45-18 Goodyear F1 Supercar Tires, less than 500 miles
Suspension; Urethane suspension bushings in rear, 1 3/8” front sway bar, 1” rear sway bar, 460lb front springs, 330lb fiberglass rear spring, front cross bar, Bilstien shocks, entire car lowered approx 1.5 inches, Power Rack and Pinion steering
Brakes: All 4 calipers are stainless steel O-ring and rebuilt, new master cylinder
See pics at www.fineairbrush.com/corvette
The paint is showing it's age, there is a previous repair on the right front fender starting to show through( still very shiny andlooks good from 20 feet).The door panels have some cracks around the screw holes but still look pretty good.The only things that do not work on the car are the clock and the parking brake. The frame is as solid as can be. The car has 110,000 miles, the motor has 50,000 from what I was told.The car runs and drives fantastic, an absolute blast to drive. I would rather not sell it but from what I hear it will be quite a hassle to get it licensed in Cali.
