1958 MGA Coupe
tonight i made the wiring harness for the parking lights, i am doing one thing different here and on the left front I am putting a ringed ground on a fender bolt just like on the right side tied into the same wiring ground harness and the parking light. i also will be bringing individual grounds to each of the tail lights, just because over the years i have realized that its a good thing to have solid ground connections at lights
also the parking light wires are soldered, wrapped in electrical tape (like rolling a cigarette, not like a bicycle handle bar), and shrink wrapped. the splices are off set. you do this becasue if you have an errant wire poking through the shrink wrap when its heated and the splices are in the same place you can create a short or other funny wiring problems. wrapping it in tape and then shrink wrap minimizes the poke throughs
this soldered splice is off set but it sure doesnt look like it in the photo, the off set also lets it slide through the tubing easier
glued the under dash pad in place. the funny thing about contact adhesive is that you paint both of the mating surfaces and you have no ability for repositioning once its made full contact
so i did this in 4 steps....the first was the middle vertical panel with the big hole and that big hole for the wiring harness was my spot that i aimed to get perfect and then i painted the side to the right , and then the side to the left. lastly i did the heater shelf portion as one unit moving from the back to the front. this made it small enough portions that i didnt screw it up. then when it was in place i cut out the heater shelf hole and brake pedal hole.
those are basically the section lines i wound up using
sorry i cant rotate these for some reason
i let hang over my lower support square tubing and painted it
looking at it from the engine bay
and done, use a small roller to make sure everything is pressed flat
the inner dash pad is a pretty substantial piece, i believe it will work well.
today continue with wiring harness install and put in the headlight dimmer switch. i marked the dimmer switch input with a white dot so for future reference you can see it easily. the dielectric grease also works well to help the grommets slip into place
how much extra wire and i suppose to have down at the dimmer switch end?
move to the wiper motor bracketry
the end of the hanger right before the hook works well for grabing a stud
oh yeah i agree, i actually see an end....
take out dipper switch wiring harness so it can go through the MC bracket, sand and prep the MC bracket, grease the wiper motor and test it and paint stuff, test voltage regulators
sand MC bracket and use some metal prep on it.
test wiper motor with power supply
greasse it up with some of my green goop.....i found a thin washer folded in half in the gear area????
painted wiper motor and tubing
havent we become high tech....power supplies and tablets to read up what you should be looking for
look at that 19v in and 15.4 at the post and all the magic happened at about 16.4 volts
cut out at 9.3 and cut in 12.9...still need to work on the second regulator it is off by 10 volts...
tonight match up fasteners for the electrical parts taht get mounted on the fire wall, i carefully put all screws,washers and nuts back on the parts.
wash with warm soapy water
spray with clear
clean terminals stuff with paper and use cardboard to blod off internals and spray with clear
well my preparation for the grommet install was not as good as i thought.....too many parts left over, and my fingers are exhausted
i guess tomorrow i will spend some more time researching what goes where
i have all the cables for tach speedo, choke, starter, heater valvbe, water control taken care of as well as blanking plugs for the brake assembly and the oil pressure line
wiper motor ready to go in
if any one wants to identify the remaining grommets please do.....i do have holes left over for the wiper motor cable, and the water temp capillary tube
worked a little more on the harness....all the grommets are in place except for the water capillary , it s looking pretty good up close and in person....
today do more on the wiring harness, install the wiper motor, hook up some wires, add vin tag and tags to heater....about 4 hrs of work.
added a rubber gasket fron a tire tube to the wiper motor post and used a leather punch to make the hole
installing these wiper motors is a PITA...
hook up wires and made this long so its easier to replace, my flasher unit doidnt pass testing so i need to buy a new one
it says thanks
more electrical work...
connecting tool in action
full compression
adding a ring and additional ground circuit to the ground to go to a body bolt on drivers side
test all circuits to make sure everything works
yes sirreee its close...
worked on those triangular pieces and putting down cork for the frame to body spots
some black goop for an air tight seal
this spot has to be below the goal post top
i used rivets to make it nice and tight
seems like a gasket is a good idea here
and lastly put in the fuel sender unit
made some progress tonight unclogging my vacuum port on my HS4
i was able to open up the port, this was .030 mig wire
got the hole open
turns out to be about .060
it must have been debris sucked into it i didnt really have to remove any metal to open it up. now what do i put in there to mate up to this
any and all ideas appreciated, what have others done who are using HS4s
thanks bob
and done, after thinking about it way too much i just drilled the hole. theres no reason not to take the carbs off if you wanted to.
i used an air vacuum ( for AC systems, do not use a shop vac around gas fumes) to clean out the carb infront of the butter fly
chucked up the bubble flair and did some file work on the profile
just waiting for the rebuilt distributor to hook up the vacum line completely
and time to take car of an easy one
any body have a good cleaning method for this original bottle?
sand , clean, sand , clean....prime and then paint
