small bites as usual, last night i painted the brackets
dont ask me why but there are three different hole sizes for the holes for the caged nuts...one size for the bottom and two sizes for the top...of course there is
so carefully pull the tabs close together or make the small holes on the top bracket bigger
i did say carefully right?
no problem I have another one that is an original
looks like cross slotted on the outside with a washer and hex head on the inside
well i gave my welding table to my son along with the wood working equipment......so what is a poor boy to do???? 5 hours worth of work by Grandpa....those 9' pieces were heavy....
remember this, lintels from old brick houses that are being torn down.....9' x 3x5 x 5/16 USS steel... and 6'x2 1/2 x4x1/4
it will have full inner perimeter clamping capabilities and a clampng slot down the middle, top is 11"x 1/4" table size is 35 x 54. depending on how is use the 3x5 angle iron, i may do one side with a 3" spine and and the other with a 5" spine. just to give maximum vesatility. the 5" spine would be good for straightening out metal parts
wire brushed and wiped down
and sprayed with self etching primer, most people don,t paint welding tables but this is really a metal shop assembly/welding table. i need it to be clean so if i brush up against it i dont get all dirty.
well since I have the MG TD with a relatively new exhaust it really has put the MGAs 40 yr old muffler to shame. i knew i needed a new muffler but with a side by side comparision i had to do something. so i have been watching for a replacement muffler and sure enough one of you guys in NC swapped your new exhaust system for a stainless steel system and your shop sold the replaced new muffler to me with shipping it was $39. the label hadn't even fallen all the way off yet
i didnt even jack up the car
i knew when i installed the exhaust system the old muffler would come off at some point so i never torqued up the clamps to crushing torque levels
and the sound test was fantastic, it took 45mins.from start to finish
a left over Hitch from who knows where, it was under my deck
i lucked out i now have some receiver tubing
the top will be my storage shelf
some i beam from fencing a neigbor was tossing
now i need to get some 1 1/2 inch black pipe to bridge the channels and then i can tack the top down and sand the new pieces and prime them and then slip it in place
take off the bottom chrome trim the other frame is the nicest
broken screw in the bracket and the other screw was missing but i had one
the tap set tells you what size hole to drill to tap new threads, for a #6 screw its number 35 or really close to 7/64 if its not it exactly
go slow and use cutting oil , you go backand forth cutting about 1/16 of a turn at a time especially for these small taps
and after hand polishing
so the only thing these window frame needs is a new inner liner for the frame. I have a new ventilator gasket but I am not sure if I am going t put that in or not
moving on to the drivers side. so in looking at my parts, it seems the easiest path is to use the vertical upright for my old windows on the new windows
the broken tab is harder to deal with then swapping the vertical posts
i do have to drill out the one screw and probably retap
i see the camera is picking up everything other then what i want, but i am letting the two screws soak in PB blaster before i try and torque on them
so to pick up where we left off the bracket under the ventilator window is broken on the window frame i am going to use and i need to take the bracket off so the new donor pillar will fit basically drill the rivets out and pop it out with adrift
just effort from this point forward just shove and push...and i used a har dryer to see if i could make it softer I am not sure anything other then brute force actually worked
put the bottom piece on easily
and done
Jim Cheatham pointed out to me the gaskets have to be trimmed on the side the glass folds in on
the very top needed to be seated just a 1/16 of an inch more so lets see if wedging some thing in there will let it form into the position over time
its all down hill from here, i will put in a parts order tomorrow to finish up
clean it up with a 5/32 drill bit so its nice and tight
trial fit
tapped down with the rivet set tool
a hard surface to set it
hit until the rivet tools bottoms out, then move to flat end drift
fully set
back together
I use green grease its synthethic and waterproof really good stuff, on the spring and washers of the window ventialtor mechanism, i came to discover how good this stuff is when i went to clean a bearing grease tool and tried cleaning it with gasoline and i couldnt remove the grease even after soaking it in gasoline, then i knew i had really good stuff and have been using it ever since
the triangular trim piece also has a ridge in it to catch the gasket
