1958 MGA Coupe
there is a filler block
so lets make some tapped backing plates for the door hinges since getting at those nuts will be near impossible, i had two extra
make a gasket
install end cap
another gasket
homemade access hole and my grandfathers combination wrench
you can see the inner bracing that screws with access to the barrel nut
and the trial fit continues tomorrow
thanks
well the window pantograph is in place, the window is in it, the lock mechanism is hooked up and it all works the lock mechanism goes in first before door channel
next is the window weather stripping and adjust the door for a better alignment
car show
http://smg.photobucket.com/user/bobs77vet/slideshow/Original British Car Day
one of my favorites, license plate towmatr and logo on side says radiator springs.....from the kids movies carz
lets move on to the driver side
simple locking mechanism
hole above the square shaft is what you plug so you dont accidentally lock your self out
locked position
heres my trial and error result.....counter sunk held in place with thread locker
tapping plate
need to add the capping plate
heres the magic spot the front window channel is held up high the pantograh shaft is inthe hole and the pantograph wheels are just about to slip into the window channel and give it a light tap of the hammer handle and it slips in to place and the since the square shaft is at the back of the hole it can move forward and its in place
and done
and the next time i drive the car i wont have a bungi cord across my chest holding the doors closed
woohoo the assembly table is clean
and the next work to do
DSC02644_zpsc9pkbc4p.jpgs side
tonights work..... i had a noisy shock link and a broken axle strap
not too complicated
easiset thing is to just remove the shock absorper, I tried using an impact to seperate but it didnt work
just cut the link off
you know where this going
one wack
and done
lets keep pushing forward....when i did my trial body fit i made a rookie mistake and did not mark the hinges and the spacers and its been screwing with me ever since
lets put the brush seal in place and a new hinge spacer, window bump stop and window trim cap and adjust the doors so they open and close
the original remnants of the brush seal
the MGB rubber one i could not figure out how to make it work so i didnt use it
my new 1/16" spacers
rubber window bump stops from Jim Cheatham
cut off raised circle
contact cement in place
hold in place with window sitting on a small piece of plywood to push it evenly down
brush seal with clips on them
in place
with exterior trim cap on it
ok so lets finish the last body panel piece, i wanted this to fit nice and tight so i am using panel adhesive and gluing it in place to the rocker sill
make a template and cut
fold tab
dead blow hammers dont leave dings
put a crease free curve in place
and test fitted and painted
to be bonded in place tomorrow
i cant believe this took two hours....the window was 20 minutes those scuttle badges were a task, my T Rex arms just dont cut it....
the brush seal, Mike Dianna saved me once again with some extra clips
my fingers are still numb
tonights mission fit the last panel in place and put some more badging
use some locating holes to make sure everything lines up
brushable seam sealer on frame and bonding adhesive on the two parts
i was a bit nervous drilling out those holes to size for the octagon... a whole lot cold go wrong with a drill and a sharp bit over shiny paint
you sold it? I see the ebay ad is ended. The 'boss' said I could have no more then 5 cars. I have 5 cars, I attribute 3 cars to her.... problem solved.:devil:
install front grille clean garage and install door handles
glue piping in place
lets put the trim around the door and window opening
previously fitted and JIm Cheatham made these and gave them to me
make a temporary table
cut and glue to the back side, the first piece i glued to the front and it got all wavy so this is just glued to the back
now the trick to finding previously drilled holes is to pay attention to the angle of the pick
and i just dont like the way they look, oh well i will just redo them another day...
thanks, good news those must have been handling wrinkles and they have almost all gone away. maybe i will put it out in the sun today and let get warm and see what happens.
kind of makes sense because if it looked like that to start with i wouldnt have put it in
definitiely going away, just the biggest ones left now....lets see what that virgina heat and sunshine can do
