Twin_Turbo
Der Maulwurf
- Joined
- Mar 5, 2008
- Messages
- 7,575
Eggzacktly!!!
If you send your money to me, I will make your cooling issues disappear
same here.............
once again I'm just simply amazed that you are willing to throw a lot of excess money at the problem, such as an expensive new radiator, but you won't take the time to go and buy a $49.99 timing light and a $19.99 vacuum gauge to be able to answer what your timing settings and vacuum levels are to help us help you.
A new radiator may help lower your operating temps but at the same time it may also do it by masking the real problem. That's not fixing the problem, that's just overpowering it with an incorrect solution.
I've tried to make this clear on both forums but i give up now. I just don't understand people that post for help than refuse to take the suggestions that others offer. Regardless, I'm done.
Good luck to you
I am getting it tuned, so I am taking your advice. h:
Ok, understood. I'll pick up a timing light and vacuum gauge today. Forgive me for the basic questions I come up with.
OK, I'm back (7 months later) but I'm back. I haven't driven the car, so I thought I'd wait to fix the timing/tuning.
I bought a timing light and vacuum gauge.....now all I need is info on how to setup the timing...be gentle with me.
Okay, it doesn't start now...LOL The last time it was a burnt wire, this time it fires up for maybe 2 seconds then flames shoot up through the carb and it dies.
help!
Haven't touched it.
Did you try to restart it? You have spark and fuel right?
