1Michel
Core support
Frame crossmembers
(Actually, the whole frame could be)
Core support yes.
Frame, not so much. The aluminum would have to be thicker to be the same strength.
The aluminum would be thicker, but still lighter. I know a couple guys that always spec'd their OTR trucks with aluminum frames for just that reason.
But there is lots of room there too. Might be a problem under a Vette.
I for one would like to see a OTR truck with an aluminum frame. I really don't see the reasoning behind it. An aluminum or composite trailer yes but just don't think an aluminum frame truck would last very long with all the flexing involved when empty because I have seen aluminum trailers crack just from that. Besides if heat treat metal frame rails on trucks crack I can only imagine what the aluminum would do. The cost difference would be substantial for a weight savings of what at the most 300-400lbs. That kinda of weight could be lost just on steel verses aluminum rims, 5-60 gallons less of fuel, plus I would think salt would trash an aluminum frame being these trucks are subjected to those conditions.
Watch a semi bobtailing and watch the steel frame flex hardcore. Just think the less flexible aluminum would crack and also give a harsher ride in itself.
I drove trucks with alu frames.
yes they are thicker and they flex less than steel frames.
We hauled steel coils etc and they used those frames on KW's W900 L with 550 and 600 hp cat engines with 1800 pounds of torque
Fully loaded no big deal, ride was good but once empty or bob tail (without trailers) the ride was terrible.
yes Québec road salt during winter did hurt frames but the steel frames also took a lot of beating so it was about the same for both.
we also cracked a lot of frames on both steel and alu frames
We hauled 90000 to 125000 pound of steel with those trucks.
