JPhil
Huh?
I pulled & opened up the motor last night....The good news is the lower end looks fine, rolls smoothly. A few little rust goobers on the flywheels, but nothing that can't be cleaned up. The cam case looks good, although 3 of the lifters are stuck in their bores. The front cylinder slid off just fine, but the rear....
This is after I cleaned out a tablespoons worth of rust debris. It is definately 'rust welded'. I have it soaking with some super-duper penetrating oil I got at an industrial supply house, "Pro One XPL-101", which according to them kicks PBB's ass. I'll let it soak for a while, then try some heat on the barrel and see if it will break loose. If not, perhaps I'll take a sawzall to the wrist pin.
But I am as pleased as one could be that the crankcase is not full of rust & water. There is hope!
Jack, yeah I remember when 80" was a stroker hotrod and 84" (by offset machining the UL wheels to accept the larger diameter FL crankpin) was a bigass stroker.....
Getting to work on this bike was prompted by the recent death of one of the very few remaining old timer bike shop men here, he was the man I was planning to deal with for parts & help. Crusty old fart, he'd just tell you to go to hell if you walked in and asked for a Kuriakin air cleaner. But when it came to shovels, pans, knucks & flatties, he knew his stuff and had tons of parts. He was building a Buick nailhead V8 powered bike (or is it an Olds Rocket engine? I forget). It's up to rolling chassis as it sits now.
Anyway, his shop is being sold off, all those parts are going to be scattered around who knows where, so I thought I'd better jump on this while I had a chance to get some stuff I will need.
Marvin will be missed....There are fewer & fewer of them left.....
