SuperBuickGuy
wow - awesome
Your picture of the rear tire/frame rail looks like mine. I also have a 285 tire. Don't have the body on yet so not sure if I will have problems with clearance (tire to fender). My outside of tire to outside of tire width is 68 1/8". I measured the rear fender to fender max at 68 5/8". So, I'm only inside the fenders by 1/4".
I measured a stock 71 with 225's and got an overall tire to tire width of 69 1/4" so I think I'm good. I hope I'm good. Too late to change now!
wow - awesome
So now on to the fuel lines... since my body is off the frame Im having a bit of a hard time knowing what is going to fit (or not!) around frame sections. Im running 2 -8 hardlines (aluminum, because theres a few less ounces :bounce: ) If anyone has any photos of the underside of their car, specifically how low the floors are compared to the frame rails and the gap between the body and front side of the frame crossmember where the frame rails kick up (I think the pre ~'75 cars were all the same floors?) I would appreciate it!
that 3d printing is pretty amazing.
You have the same dilemma as me. I wish I would have paid more attention when the car was together. I'm pretty sure I will have to raise the transmission tunnel. As far as the lines, I think you are OK as long as they are in the same location as stock.
I'm trying to figure out how much room is between the back of the heads and the firewall because I'm running my fuel lines there.
What are you going to do with your frame jig?
Im worried that the frame rails are off enough from stock to still fit the body, but wont support another ~.625 worth of fuel line. Plus, Im trying to make as much of the car serviceable without removing the body again. The fuel lines didnt fall into that category on a stock 69' :crylol: The jig is going to stay at the fab shop for now... Not sure what to do with it
Whats too big for your trans tunnel?
thats amazing is it strong enough for a real mock up like those fake mock up engines?
Thanks!Looks good.
that looks like the tank I built for my last C3, it may even look like the tank I'm going to build once I get the Camaro suspension under mine. Are you going to make it out of 16ga, 304, #4 finish stainless steel?
for what it's worth, the minor weight savings of aluminum compared to the non-reactive attributes of stainless. My napkin math says the stainless tank would be 50 lbs vs. 35 lbs for aluminum... if you really want to be good forever, 316 2b (what they use for tables in science labs).... hmmm, now I'm thinking about building mine out of it too - my first step is finish my plasma table.
truly just my 2 cents, if it helps, cool, if not never mind me :suspicious:
