clutchdust
Millionaire Playboy
Eat your wheaties, but you should be able to tote a bare block by your self. Getting it up is the only problem.
That's a good deal incl the line honing with your girdle. That's the splayed main caps, correct ?? Is drilling the additional angled holes and tapping the threads also included ??? If so it's a great deal :thumbs:
Negatory, my 2-bolt regular main caps, bored/honed with stud girdle in place.
The man says a 2-bolt w/stud girdle is just as strong as a 4-bolt.
And good enough for my HP goals..400-450 at the crank.
BTW he said what all of you have been saying;
Don't go 060 on a SBC 350, absolutely don't go 060 on a SBC 400.
He's been looking for a 400 block that is usable for a year.
Now I know that you knew that you were right but sometimes it's nice to hear that you were right.
How the hell am I going to get that block in the back of my wife's SUV by myself?
It's time for a beer..or two...:mobeer:
As usual hit another speed bump in my 383 build.
Have been quoted $750+ by two local machine shops for 030 overbore, freeze plugs, oil galley plugs etc etc.
That's about double of what I expected to have to spend.
I planned on my '74 2 bolt 030 overbore and a main stud girdle.
Here's the kicker; I can have a 4 bolt 383 block ready for assembly delivered to my door for $795.
Required a dead lift from the ground up and into my wife's Grand Cherokee. Good thing I have a weight lifter's belt. Would have been hilarious driving around in the 'vette with a bare block in the passengers seat.you should be able to tote a bare block by your self. Getting it up is the only problem.
Went to the shop yesterday, block was almost done.
Getting ready for the final hone
"Virgin" block, no more numbers:
for $700.
- Align bore & hone the mains
- 030 overbore & hone
- Twice in the hot tank
- Square and decked (0.005 of the top)
- Stroker clearance
- All freeze plugs and galley plugs
- Cam bearings
- Paint
I don't think that's a bad deal considering I was quoted $750 for half the work.
Plan on ordering the rotating assembly this week, see if I have any money left to get the heads also. But still haven't figured the final cam choice, but it will be solid roller...
[*]Align bore & hone the mains
Hey CNC, if I read your post right, you're telling him that his machine work is shit and his engine is going to explode the first time he puts the hammer down. Is that about it? 'Cause that's what it sounds like you're saying.
Well the man says he shaved 0.005 of the caps and then align bored and honed.Why did the charge you for a line bore and a line hone as it makes no sence unless the caps were changed!!
Irrespective of the block selected, a performance rebuild should include align honing. Many machinists either overlook or disregard the importance of align honing. But every critical block dimension is taken off main bearing saddle alignment, so align boring and/or honing should be the first machining operation and it must be done accurately.
Rather then argue with me just call Sunnen and talk to the hone department I am sure they will clue you in on what it takes to hone a block correctly and what machine is needed.
Look around some of the top engine builders shops and some of the cup shops you won't see them guys using a 5000.00 hone LOL
UH..some assumptions being made here.
For starters how do you know the main caps were not torqued during the hone?
I took the picture right after he installed the torque plate with a gasket.
Forgot to ask him if he honed the block hot, I'm sure that would have made a difference too.
According to an article in Engine builder :
11/1/1996
Performance Small Block: Chevy Engines
By Dave Emanuel
Well, first of all, we are not the ones arguing and no doubt Sunnen will tell you that you need a Sunnen.
The guy's been an accomplished swamp buggy and drag racer for the last 20 years, building his own engines. Other than that I know nothing of his work. For all I know he may have just posed for the pictures, aged them with tea and hung 'em in his shop.
He might turn around and hone it with #80 sandpaper and a brick for all I know, but I doubt it.
In the mean time the assumptions and critique are getting a little "abrasive". You are obviously very knowledgeable but there is really no need to put an exclamation mark at the end of every sentence.
1) You are making some serious assumptions about what I think/know
2) You should go back and reread some of your posts as if you were the OP and someone was saying to you what you're saying to him.
I am not in any way contradicting what you say. So far as I know it's absolutely correct. I'm no machinist, but I've built an engine or two. My point is that if the OP is anything like me, he may be on a budget. Otherwise, I'm sure he would have simply started with a fresh Dart or Donovan block. He also may be looking for the best bang for his buck. There is with out question some machine work which absolutely has to be done correctly regardless of if the engine is a "going down the road" motor or a pro stocker. There are some things that may not be quite as necessary for an engine that will, for instance, only see 6k rarely, or the builder has no need/desire to make 400+ hp.
I trust you are exceptionally knowledgeable in what you do, far more than me. And you sound like the kind that insists on doing everything the *right* way. For some of us, especially those of us on a budget, there may be more than one right way.
I think your very knowledgeble opinion could simply be stated in a way that doesn't make the reader feel as though it's your way or you're just pissing away money.
Food for thought.
Look Carl, you're in Maine, I'm in Florida.
You charge $595, he charges $850, made me a deal for $700.
You use Sunnen, He doesn't.
You shave 0.003 (approximately), he shaves 0.005 of the main caps. BTW he told me that before he did anything. Shave 0.005, line bore and hone.
I really don't see a problem here.
What's next, that I should be using Craftsman instead of Snapon tools during assembly?
Oh boy, all these millions of blocks that were not honed using Sunnen equipment are going to explode LOL
