CNC BLOCKS
What's next, that I should be using Craftsman instead of Snapon tools during assembly?
Thats to funny but I can see the truth hurts some times.
Its still to funny LOL
I always tell you got exactly what you paid for nothing more.
At our shop we
Sonic test
Clean and Mag
Line hone
square and deck to zero
Bore and plate hone use the same gaskets and hardware to be used in the end build.
Light hone on the lifter bores
Stroke clearance
Drill water holes in the decks on certain GM blocks mostly the earlier ones.
We charge 595.00
Yeah I thought that was funny too.
I think I'm going to ask the guy my money back since he didn't mention hot honing my block.
Oh..wait a moment, neither did you.
Funny since you seem to be an expert in the field.
At our shop we
Sonic test
Clean and Mag
Line hone
Stroke clearance
We charge 595.00
Nope, hot-honing is not on there.
Funny that it's mentioned here:
http://www.circletrack.com/techarticles/cylinder_block_honing/index.html
and here:
http://www.aa1car.com/library/plateau_finish.htm
and here:
http://www.enginebuildermag.com/Article/1087/has_hot_honing_cooled_off.aspx
Here is some really good reading by the way:
http://www.aera.org/ep/downloads/ep11/EP07-2010_42-48.pdf
Now wait just one moment....Sunnen makes one, didn't they tell you?
Maybe you should buy this one for your shop:
http://cgi.ebay.com/Hot-Hone-Sunnen...047?pt=LH_DefaultDomain_0&hash=item41577032b7
Or this one:
http://www.c-ktechnologies.com/images/hothone.pdf
Then you can tell everybody that their block is shi-ite since they didn't hot hone.
Now stop being an @ss about these things, play nice and I'll let you answer some of my other questions....:kissass:
Lance Patton, Tom Vique 3V Performance, Carl Hinkson CNC blocks. Thanks Guys
Your very welcome. Great job!!!
Thanks for letting us help.
Tom
3V Performance
"ENGINES WITH AN ATTITUDE"
Custom race engines
Machine shop
Dyno service
50HP Spintron
828-302-4088
Here is one of engines that came out of our shop that went to CA and has been running for 2 years leaked it down last week number were really good going to just change valve springs and run it another year.
OK, so sarcasm and irony are lost here. Never mind, I'll play.
Third page from the first link you provided:
Tom
3V Performance
Custom race engines
Machine shop
Dyno service
50HP Spintron
828-302-4088
You state:
So who built the motor now, 3V Performance or your shop?
It seems you've done the cam and block.
Not that it really matters since it's hardly a street motor:
[ame]http://www.youtube.com/watch?v=CM2_4AAIGCM&feature=player_embedded[/ame]
But since you keep comparing apples to oranges let me give you an opportunity to beat your drum a little longer;
I will now try to be nice again;
What solid roller cam would you recommend me:
Aluminum heads 64 cc chambers 210 cc runners intake flow 258 @ 500 exh. 193 @ 500
2000-5500 dual plane intake
Q-jet carb
10.4 compression
700R4 transmission
3.08 final gear ratio (for now, maybe 3.55 later)
and would you recommend I run a rev kit yes or no.......
That is one bad-ass motor Carl.
I have Morel roller lifters already, so I guess that's a good thing.
Thanks for the Ultradyne number, I'm going to be crazy busy at work the next couple of weeks but I'll try to get something done.
I've had Skip White's aluminum heads on my list for a while, guess they are Procomp
http://cgi.ebay.com/ebaymotors/SBC-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Not sure if I should go for the 190-ies or the 210's. Need to give him a call also.
Open for other options but the budget limit for heads is $850. Be gentle now....:club:
