vette427sbc
COMPLETE 700r4 SETUP
700r4 Trans...Professional rebuild by Ziggy's Transmissions in NJ less than 15,000 ago. Rebuild included:
New seals, gaskets, teflon and o-rings
New filter
Hardened Transgo pump rings
New .471 boost valve & sleeve
Raybestos Pro Series 2-4 band
Rabestos Heavy Duty 3--4 Z-Pak
Shift Kit
Hydraulic lock-up
Corvette servo
Corvette governor
Hardened sun shell
020 Valve & sleeve
New BW rear roller set
Heavy Duty 2500 stall speed converter
Complete bolt in set-up includes
168 tooth flexplate (came off of a 1pc rear seal block)
trans/converter dust cover
tv cable
TCI custom tv cable brackets for correct cable operation with a Holley carb
dipstick and tube
Hurst ratchet shifter complete with cable, hardware, handle, ball and console
yoke for a 700r4
finned aluminum tube style trans cooler
trans cooler hard lines for a tri-five chevy
**Yoke and custom tv cable carb bracket are not pictured.
This set-up has less than 15,000 miles on it. Asking $1100
Located in central New Jersey, zip- 07760
New filter
Shift Kit
Hydraulic lock-up
Corvette servo
Corvette governor
Hardened sun shell
020 Valve & sleeve
tv cable
dipstick and tube
yoke for a 700r4
