The camera battery died before I could take pictures of the perch but essentially I removed the old hood loccking perches. The drivers side was easy to install. I just marked the hood and drilled down. The power booster attachment kickout was high enough that I had plenty of adjustment.
The passenger side took some playing with because it sat 2" lower than the area where the drivers side mounted. I came up through the wiper well with some 1\2 -20 threaded rod and then used a threaded shank nut on top . I screwed the pin tower into that and had plenty of adjust ment.
I wanted to get this done before paint so if I screwed up it could be easily fixed.
Wade
Wade
