saudivette
Clueless In Sandland
I'd imagine a lot of you guys have already modded or upgraded your steering and/or brakes and the associated plumbing that goes with it, but for those of you that haven't or are contemplating converting to Hydroboost brakes and a Jeep steering box, here's a schematic I knocked up ages ago with all the plumbing fittings that you'll require. It makes it a little easier to get your head around it all when you need to buy the parts - well, it did for me anyway!
I bought the high pressure stainless fittings and -6AN braided hose from Hydratechbraking.com but on the low pressure side I used anodized Aeroquip fittings I bought on eBay. Depending on whether you have a pre or post 1980 power steering pump will depend on what fittings you use on the pump outlet - I just used the older style pump that was already on my car. 80 and newer should have a 16x1.5mm metric 'O' ring style fitting.
I hope it's of some use to someone...
