Radiator surface required is 1.5 sq in of surface area per cubic inch of the engine. For example: LS1 V8 Chevrolet = 350 cu in x 1.5 = 525 sq in of radiator surface area required. For this purpose, this applies only to the surface area of the radiator that the air flow first makes contact with.
Minimum of 3.0 cu in of cooling volume per HP produced.
For example: We only utilize up to 300 HP of an LS1 for aircraft use. Using a dual radiator configuration with two radiators measuring 15” x 18” x 2.25” thick = the total cooling volume is 1215 cu in.
Therefore, our cooling volume to HP ratio: 1215 cu in cooling volume ÷ 300 HP = 4.05 cu in per HP. With this formula, we have been able to maintain climb out temperatures of around 200°F and 190°F at cruise on a 100°F day. With a cooling system like this, we could taxi from Houston to Dallas with no overheating problems.
Use all aluminum two pass radiators. We recommend that your high pressure system consist of all aluminum radiators configured to a two pass system, which increases dwell time in the radiator, and enhances heat transfer even more. Hard plumb as much of the water line as you can, using minimal rubber radiator hose for increased durability. The fewer rubber hoses you have to watch over, the better.
Exit air volume. In order to keep the air moving through the cowl it is recommended that you utilize 1.5 to 2.0 the amount of the fresh air inlet for the cowl exit air. Failure to have enough exit air volume will make the engine run too hot or even overheat. This is more difficult to achieve with a retractable gear airplane but must not be ignored. Ground and taxi testing may produce successful results, only to have the engine overheat on climb out due to insufficient exit air volume now that the gear doors are closed, dramatically cutting down on the exit air volume.
Use water for engine cooling, and add only enough antifreeze to keep it from freezing. Water takes the most heat energy to change its temperature than anything else and that makes water the most efficient in terms of its ability to conduct heat with minimum temperature rise. Antifreeze, or ethylene glycol and propylene glycol, have higher vapor points and therefore can absorb heat at higher temperatures without boiling. However, even with its lower vapor point, water still carries more heat per unit than other coolants. Better still - use Water Wetter - no ethyl-glycol on the track!
Use the right radiator cap. An overlooked or under considered part of the cooling system is the radiator cap. Use a 22-24 lb radiator cap, which will raise the water’s effective vapor point. For every point of system pressure increase, the boiling point of water will increase by 3°F. A higher boiling point will also reduce evaporation loss, water pump cavitation and heat soak induced after boil.
