Internal Body Aerodynamics
[ame]https://www.youtube.com/watch?v=xY8x7TAVaOg[/ame]
You have to pick out the aero devices, as this is more of a review.
He trashes the Nissan, “most over-priced.”
6 yrs old, but interesting graphics.
[ame]https://www.youtube.com/watch?v=Ek_f0jKRbNY&app=desktop[/ame]
[ame]https://www.youtube.com/watch?v=dacP372xljI&app=desktop[/ame]
The front splitter/spoiler is pretty wild looking. Uploaded this week.
A one off custom made Ferarri? I'll bet that cost some big money.
Beautiful car!
Yeah, when the Ferrari employee thanked the buyer for the opportunity to design and build a car, I figured it must have been a blank check ( i.e., no budget worries). :)
Pretty cool how YouTube AI feeds up new videos, this one was only up 2 days.
Seems like if you want to keep abreast with automotive aero, you have to watch the really high end stuff.
[ame]https://www.youtube.com/watch?v=44j_ZBZdXXA[/ame]
On the 68, 69 years they have the 4 grills behind the front wheels.
1 of the grills is blocked off, if it was opened up to the wheel well could it pull the air out of the wheel well?
That is a Great Question. I had to go ask the Oracle:
Then, since my car is so torn up, a little digging on the chassis details:
The challenge to getting the air out of the wheel well will be the inner fender well. With some modifications, yes, I bet it would help. And, you could eliminate using the “over fender” louvers. [There is an additional advantage to the louvers as they dump air into a low pressure zone…]
But, you could with a small-ish, cheap fan – get air from the engine compartment quite easily. I bet there might be bigger pay-off to that with under-hood temperatures, including an oil cooler, and a major source of internal drag!
It’s all a trade-off. Best of luck. Thanks for getting me thinking!
PS - Found this over at Pro-Touring [checking out front suspension builds] It clearly shows where you'd have to mod to work the wheel well through the "gills." I bet it could be very useful with a duct from the existing well to the gills. Enjoy!
Not easily... the other gill (if opened) would evacuate air from the cowl. The other thing is that the body mount is in the way. I have already clearanced mine about as much as I feel comfortable.
Very rough mock up of my cooler:
Hard to see, but I took a fair amount of the triangulation out of the body mount to allow a smoother duct
It will be interesting to see if it needs an exhaust fan. Nice work on the install.
What I have found with those gills is, after a race they are covered in brake dust. So me think that I do not have much air flow exiting the engine bay to push that dust out. And the steel plates at the bottom of the guards are there.
Confused....
I remember of a race cars engineer I was working with, who always asked me not to clean anything post race, for him to have a good look at how dirty the car was in certain locations . Must be a sign ?
Confused.... I'm confused about the steel plates and guards you're referring to.
His request to not clean/tamper with the car makes sense. :thumbs:
There are metal plates that bolt to the bottom of the fenders and tie them to the bottom of the wheel well... mine (stock?) were steel. Easily replicated in aluminum :amused:
I had them in my hand a month ago and didnt even think about it! That post triggered my memory :lol:
Thierry, If you can remember next time youre out, some before and after photos of your fenders and brake dust could be helpful in seeing where the air is flowing on these cars :rose:
Yes I will. Well? I need to remember it !!
This remind me of another thing.
Hot days at the track are really common here like 80 to 95 F deg, and no wind.
So on the track all my temps are under control, but coming back to the pits this is where my motor start to get hot, heat sink and under drive W/pump.
So I bought an industrial fan, 60 cubic meters to cool it down, with bonnet 10" opened.
Then I went on to check the airflow going through the radiator.
Well? Surprise ! Lot of air passing on top of the rad ( Good for intake ! ) but not that much ( I think ) going through.
I then used a ribbon to check it again, most of the air flow appears to pass/glide over the core of the radiator !!
Back in the workshop I made a deflector the length of the radiator and 2" wide and positioned it mid core.
2nd Try, way better !! You can really feel the air passing the radiator to compare with the top section.
I wonder now if a smaller radiator but upright, could be superior to the original.
That is tempting, but first I'd want to run some numbers -- and make sure the sides, top and bottom of the radiator are focusing the air through the radiator core - and not around/over it.
These "requirements" are from a page that works V-8 engines in experimental aircraft (Ravins). They max out at 200knots and cruise at 140-160, so good numbers here too I'd think. I've eliminated those that were aircraft specific.
Radiator surface required is 1.5 sq in of surface area per cubic inch of the engine. For example: LS1 V8 Chevrolet = 350 cu in x 1.5 = 525 sq in of radiator surface area required. For this purpose, this applies only to the surface area of the radiator that the air flow first makes contact with.
Minimum of 3.0 cu in of cooling volume per HP produced.
For example: We only utilize up to 300 HP of an LS1 for aircraft use. Using a dual radiator configuration with two radiators measuring 15” x 18” x 2.25” thick = the total cooling volume is 1215 cu in.
Therefore, our cooling volume to HP ratio: 1215 cu in cooling volume ÷ 300 HP = 4.05 cu in per HP. With this formula, we have been able to maintain climb out temperatures of around 200°F and 190°F at cruise on a 100°F day. With a cooling system like this, we could taxi from Houston to Dallas with no overheating problems.
Use all aluminum two pass radiators. We recommend that your high pressure system consist of all aluminum radiators configured to a two pass system, which increases dwell time in the radiator, and enhances heat transfer even more. Hard plumb as much of the water line as you can, using minimal rubber radiator hose for increased durability. The fewer rubber hoses you have to watch over, the better.
Exit air volume. In order to keep the air moving through the cowl it is recommended that you utilize 1.5 to 2.0 the amount of the fresh air inlet for the cowl exit air. Failure to have enough exit air volume will make the engine run too hot or even overheat. This is more difficult to achieve with a retractable gear airplane but must not be ignored. Ground and taxi testing may produce successful results, only to have the engine overheat on climb out due to insufficient exit air volume now that the gear doors are closed, dramatically cutting down on the exit air volume.
Use water for engine cooling, and add only enough antifreeze to keep it from freezing. Water takes the most heat energy to change its temperature than anything else and that makes water the most efficient in terms of its ability to conduct heat with minimum temperature rise. Antifreeze, or ethylene glycol and propylene glycol, have higher vapor points and therefore can absorb heat at higher temperatures without boiling. However, even with its lower vapor point, water still carries more heat per unit than other coolants. Better still - use Water Wetter - no ethyl-glycol on the track!
Use the right radiator cap. An overlooked or under considered part of the cooling system is the radiator cap. Use a 22-24 lb radiator cap, which will raise the water’s effective vapor point. For every point of system pressure increase, the boiling point of water will increase by 3°F. A higher boiling point will also reduce evaporation loss, water pump cavitation and heat soak induced after boil.
Also take a look at Grumpy's link here It gives 14 Rules for Improving Engine Cooling System Capability in High-Performance Automobiles -- like Racing Corvettes! :1st:
