My bet - the Scoop.
WHY?
The camber of the scoop is pretty radical, as compared to what Kyle was suggesting as a smoother transition in the previous video. The flow is highly likely to separate anyway, and have a region of high skin friction before the separation region.
The Dimples, surface roughness (like maybe a vinyl top recall the "drama" Mark D. + Penske NASCAR?), a trip wire, or even VGs could be used to "turbulate*" the boundary layer as well. That would reduce skin friction and by re-energizing the near-field flow help fill the region behind the scoop. Yes, I'd really like to see some CFD here. And, I bet they are using the dimples to tailor the separation zone.
Yes/No? Just one guy's opinion.
But - on the other hand - it is a cool idea (the others could work too), and the dimples on the scoop make for real cool marketing ploy and heaps of armchair aero-discussions.
I'll admit - I haven't caught the video - just yet, so these observations may be subject to "recall." OK - Watched it. He is glossing over the 10% --I'll still stick with the scoop.
OK -- I did a bit of figuring;
So what is 10%? Is it the whole car Cd?
The Chiron drag data is available and I'll use it for similitude (a cool term- eh?).
In low drag the Chiron Cd is 0.38.in drive around mode, in handling mode up to 0.40, and then drops to 0.35 in top speed mode.
Handling mode is going to have some induce drag from wing downforce increases, and the dimples only function in High Speed Mode, so I'll only use Top Speed Mode Cd.
If the Chiron had Dimples which came into function at the high speed range, And, if the Dimples reduced the whole car Cd - that would be 0.315.
WOW! That would be SIGNIFICANT.
Now to the Bolide:
Using Kyle's estimate of the Bolide low drag configuration of 0.3522. With DIMPLES it would be 0.317 (whole car) using Kyle's Cd estimate. Since the Bolide is only moderately faster than the Chiron (again, it has no dimples), I suggest the 10 percent reduction in drag on the Bolide is just the scoop. Else, there would be a much larger difference in the top speeds.
Lastly, I'll also suggest his Cd is pretty close to what we might expect on the Bolide. We must wait for further details.
I love saying this, "Class Dismissed..."
* Please not the Urban Dictionary Definition!
