BTW....You never said anything about the razor blade method.....
My experience with this method is it generally only works on Lacquer Base paint jobs.
I stripped the entire front of our car with a blade because it had been RE-painted
and the front clip had been primed with a Lacquer Primer.
It all pealed off till I hit the original paint then I "had" to sand to remove the original BC/CC job.
The hood I took to the shop and used a HOG.
If you use modern materials and the car is prep properly you should not be
able to strip the paint with a blade.
