Ok let me talk this out and make sure I understand. You took a "T" fitting (3 ports essentially)placed it inline of the feed line from pump to carb. Blocked off the 3rd port which should be the leg of the "T" and then drilled an 18 inch hole in the blocked port ("T leg") and ran the return line from there to the tank. Correct?
Lars, from your suggestion above can the same thing be done with your setup?
So in both instances there is not need for an actual regulator as long as you have the restriction correct?
Thanks for the info and patience guys!
Yes, you can use a "T" with a blocked and drilled port. The closer you put it to the carb the better the system works, and the very best system is if you do the "T" at the rear end of the fuel log if you're running a Holley or BG dual inlet carb. If you have a Q-Jet, put the "T" as close to the carb inlet as possible. If you use an "AN" fitting, you can have the one leg of the "T" plug welded, and you can then drill it out. A .060" diameter oriface works pretty good with a stock volume pump.
Lars
