:lol:
that laser is awesome
what's the computer for?
Main purpose for the carputer is vision, 2 camera at the rear, two at the front, I have a 7" touchscreen hi-luminosity panel that goes with it.
From there you can add GPS, MP3 and such. I plan an arduino-based module to sense voltage, fuel level and such, maybe I'll display my gauges on the screen too. For sure I'll do data logging.
With an antenna I could access the web, but I don't think I will, for security reason.
The car will be running long before this thing is functional, this is a much longer term project.
wow, that reminds me of Knight Rider in the 80's ..... would be cool to have fuel level and water/oil temps on the screen.....
I went to school in France, (near Geneva)
You're talking about my homeland there. I was born and grew up in a village halfway between Chamonix and Annecy.
Well I dont want to keep highjacking Denpo's thread with my hockey stories.
LOL
But we will make a mold... of a hood not a body armour.
Derail it at will my friend. Chair ridden as you are for the moment, I'm sure everyone will be glad you'll take some recomfort messing with us.
Bought some gelcoat last week, I'm dying to make a long LT-1 hood.
I went to school at Collonges-sous-Saleve... halfway between Annecy and Annemasse. I have some really neat pictures of a trip to Annecy - IMO the most beautiful place that I've ever been.
Man, I'm from Cluses, pretty sure you've been there at least once.
Yeah, the place is beautiful, I miss the mountains. I don't miss the people's mentality tho.
Damn the world is small.
Well, I'll try to do something more tasteful and that ages more nicely, but yeah, that's the idea.
Ouch, hurt my back while doing acrobatics yesterday.
The garage, while heated is still a good place to get cold, I stay in the warm for the day.
So I booted the clear taillight mod. I like the bubble lens design, but since I'm running colored led, I don't need the red of the lens.
I'm taking inspiration from here :
http://www.alumilite.com/howtos/TailLightMoldingNoEquipment.cfm
I'm not using their product, it's playdoo instead of the molding clay, and this as rubber casting product, from local resin supplier :
Today I made the first half of the mold :
I know the lens in itself is not perfect, but I was afraid doing worse than better trying to polish it.
I hope it won't show.
Now got to ways 1 to 2 days.... soooo long.
if the clear lens has some surface imperfections, don't worry. sand the clear lenses with 400, then 600 grit and clearcoat them. I've done this many times with old headlight lenses, even the ones on my C6 are clearcoated. that automotive clear holds up much better than plastic, and you can wetsand with 2000 grit and buff it to mirror finish.
Roger that Karsten, thanks.
If the casting material is water clear polyurethane, you need to do what Karsten suggested anyway. The clearcoat will help protect from UV. Unprotected, most polyurethanes turn yellow, then haze over.
Casting material is clear epoxy I got from the glassers' shop. They didn't have the 2 part rubber, so they directed me to a all resin supplier.
There, I saw they also have and "optic resin", supposedly made for lens and such.
If the current epoxy don't give good result, I'll give this one a try.
I will smoke them a little, my LED are so damn bright anyway.
And yes, UV protection clearcoat will go on top of that.
Soooo, looks like there is no way I could find a cheap late C3 3 pieces.
Nevermind.
I bought a mold from my local Corvette hoarder, 20$
It does appear something is missing. Trimming may present a problem.
If I were closer I would help you with it.
Ok, taillight mold done.
Few problems : my release agent did work at all, I had to cut the contact surface on the outside to set the two part free. So I expect a mess at the flashing surface.
Removing the tailling for the mold have been a real PITA.
Instruction on the webside don't mention the use of release agent when casting, I'm a bit concern the cast part with break upon release. We'll see.
And of course I couldn't entirely get away with bubbles :
It's still minimal, hopefully the ouside of the taillight will be bubble free.
Can't wait to test it out.
I used aluminum foil as a barrier whn I made my speaker enclosures, cooking spray like "Pam" is an excellent release agent ..... and cheap..... and very covinint because it comes in a spray bottle.....
:smash:
:smash:
Believe it or not Karsten, but that's what I used.
But, people from my tribe still cook their food with primitive stuff like oil or butter.
So, when I used it (for the very first time), it first sprayed something very watery. I said to myself "well that must be the wizard thing people talks about".
And it wasn't.
Found out layer it had to be shaken and suddenly is spray something that looks like fat material.:blush:
Joys of space-(gar)age cooking :push:....
Hi guys.
After another unexpected hiatus I'm back in the garage.
I used the crappy molds I bought and got my self a 3-pieces spoiler set.
Pretty much as planned the center piece came out nicely, mold was ok and the shape was simple.
On the other hand the side molds where ugly I had to destroy the mold to get my parts out. And they fit pretty bad....
...especially the driver side.
Not really unexpected, the front clip came from a unfinished restoration and clearly things have been done there before.
I'm a little concerned about the back side of the side spoilers, do they have to follow the wheel arch shape? if so I'm in for some heavy massaging.
That was fun doing those parts. I gained first hand experience with gel coat and mold preparation. The next one will be muuuuch better.... a lt1 hood scoop.
I'm also done with the shutdown controller for the embarked PC.
It sense the 12V acc and trigger the boot of the PC. When it stops sensing it, it wait for a couple of seconds, then trigger the shutdown.
It controls the power relay for the computer itself and another for the to-come sound amplifier.
The code in the microcontroller always make sure the computer boot up and shutdown cycles are fully completed.
When the car is off, only the module is powered, I still have to measure it, but the amperage it draws should be negligible.
