Hello fellow vetteheads. It's been a long time since I've last updated.
Last year's work on the Corvette ended up with an engine failure at the first try.
Turns out I'm probably the one to blame since it appears valves' lash were totally out of wack, to the point the rockers were floating at some point during the cycle. The engine ran at most 4 time during the 8 years of the restoration process, only a couple minutes at a time and yet it seems it was enough to get the lash completely off. Could it be it's a flat tappet engine, you tell me.
So yeah, it pretty much ruined engine right from the start.
Well, maybe no ruined, but it would take to have the engine apart to really tell.
The amount of work to investigate is pretty much equal of an engine removal, so, since I have this 5.3 LS I assembled the year before I decided I'd go straight for the LS conversion that was I end goal.
If all goes well I could inspect clean and fix the SBC later for resell or whatnot.
So here I am with a fresh new plan and energy. Morale was low after the engine when kaboom, but I got over it, took time to work on other non Vette related task that were taking dust in my todo list and now I have needed time (and probably $$$) to make it happen.
This LS engine started with the purchase of an L33 shortblock on the LSTech classified, got it for 700$, I think this was a fair price.
From there I purchased from many sources (ebay, forums, kijiji, scrapyard) the missing parts at the best deal.
Basically what I got now it a 5.3 LS6 engine:
Flat top stock pistons.
used 799 heads ported in-house.
used LS6 stock cam, pushrods, rollers.
new LS6 valve springs.
Double roller timing chain.
Later LS6 valve cover.
Batwing oil pan.
Truck harness I rewired for car use.
Truck cable actuated throttle body.
Truck MAF.
At the time I had the engine put together (but not assembled), just to make sure the big LEGO was completed.
Now it's time to disassemble every again, take the shortblock appart and inspect everything.
Cylinder walls (1 to 8):
While cylinder wall seem to still sport the honing pattern, you can clearly see cylinder #3 has seen better days.
Scores can catch a finger nail and match small score on the piston between the top and the compression ring.
Is it doomed for reboring or should it be ok to use as is?
Main bearing: (top and bottom, 1 to 5)
I'm no expert in mail bearing, I just found that bottom bearing looks nicer than top bearing, but that's all. I'd love you guys tell me what you think of those.
Since I'm right at the start, if you guys got suggestion on what I should upgrade/replace, I'm listening with both ears.
Thanks for reading me.
