Is the vapor line on the water pump something you added? What is it's function?
Yes, I did drill and tap the hole. LS block have vapor lines that you're supposed to connect to the top of the radiator. Since I don't have this connection the simplest way to eject those water vapor is to route them to a high point in the water pump. It's a rather common mod for LS swaps. I should post a picture once it's connected.Is the vapor line on the water pump something you added? What is it's function?
Here I thought the top of my SBC with LT1 injection and HEI up top, looked like a mess.....that LS blows my mess away.....:clap:
Thanks, I have to admit I wouldn't have gone anywhere without all the precious information on lt1swap.com, this website is amazing for LS swaps.Your making quick progress. All that wiring would make my head explode!
Where did you find the fuse/relay box?
Thanks!I use a bunch of different tapes by Tesa... They make the cloth-like tape, but I wouldnt recommend it for engine compartment stuff... They have all different types, but I dont know any stores that will carry it in stock. Mostly an online order type deal. I have used 3M super 33+ for engine looming before, as long as its not near any major heat sources like headers its fine. Some heat shrink or even a zip tie at the end of your loom will prevent it from unraveling.
http://www.tesatape.com/industry/automotive
Looking great! :beer:
I definitely don't get reply notification, whatever the setting.The vinyl wrap was used in the engine compartment harnesses, but after dissecting more than a few 60's/70's GM engine harnesses, I can tell you It doesn't fare too well with 100+ degree heat cycles. It becomes brittle and falls apart in the higher heat areas. That being said, it is far nicer to unwrap should you need to service something...
but who knows, maybe the 3M super33 will do the same thing after 40+ years :clobbered:
Yep, that was my though. Just got the line, I'll see this evening if it fixes the issue.I don't think you would want it riding against the PP fingers all the time, that would probably lead to noise, heat, and premature failure. The throwout bearing is typically supposed to sit back just a few thousandths from the pressure plate when the clutch is engaged.
