mfain
For those interested in converting a throttle body (or carb) to drive-by-wire, here is how the linkage from the BMW drive motor to the Wilson Dominator TB worked out.  No slop and the throttle position indicators on the drive motor and TB stay in sync.  I had to remove the throttle return spring from the primaries in the TB, but if you lose the linkage the MoTec ECU will shut the motor down if there is a discrepancy between the TPS's.
