I like your heat shield. Is that aluminum wrapped tunnel shield?
. I ordered the last of my plumbing from Brown and Miller, so I am getting very close to firing this thing up.
Thanks Jim. My design. If you notice the cut-out in the floor pan, there is another recessed eye bolt attached to the frame in the center that I can use for a center crotch strap so I can go 5-point, 6-point, or 7-point like the new Simpson belt.Pappy -
Very cool bearing surface for the sub-belts. You come up with that? Or - TKO pan?
Better than many of the of-the shelf "spec" solutions - just a slot in the seat pan.
When you tell me you added ankle straps I'll think you are having a senior moment and have gone back to your F-4 days. LOL BTW, the crotch straps in my photo are Team Tech - the harness out of my Viper. I saw that Team Tech has a 7-point harness available like the Simpson. The one thing I like about the Simpson is that the lap belt adjustors are on top of the thighs, vice down at the side of the seat where they are hard to get to. I don't believe the Simpson 7-point is FIA certified either. Just FYI, something that is not visible, the 1" square bar that guides the crotch straps on my seat pan has a split 3/4" tube wrapped and welded around the bottom of the bar to keep from having a sharp edge that would wear the straps - if that makes sense.Pappy -
Excellent. Will incorporate in my seat too.
But, I'll see the Simpson 7 and raise it to a Team-Tech 8 point. Been using one on the SR, and it fits like a 'chute harness. Across your lumbar then down to the buckle. Also up through thighs/crotch--in addition to the anti-sub. A bit awkward at first, but solid. Wish they made as FIA and not just SFI. View attachment 53324
Thanks. Here is a photo of the pivoting master cylinders on the other side of the firewall. Time for plumbing - they need flexible lines in and out since the cylinders move slightly when you depress the pedals.love the pedal solution - when I do the next C3.....
