SuperBuickGuy
ABS would be a good addition, but what I really need is more seat time...
I'd be quite interested in the pan.I feel your pain regarding the attitude of some of the younger crowd. They buy performance and think they are the experts. I road race, but the crowd I run with isn't interested in my old, modified Vette - maybe they will change their mind when I eventually get it on track and do some serious spanking. I think that is the only way to get their attention. Even the more purist Corvette guys still give me a hard time for cutting up a classic. LOL A dry sump is a good idea, but fairly expensive. An accusump can be a crutch for the long sweepers where the oil pressure drops. A dry sump doesn't help low oil pressure at idle unless it is caused by low oil in the pan after running and braking hard. I looked for photos of the underside, front of your oil pan to see how much clearance you have behind the harmonic balancer. I have an unused Dan Olsen BBC road race plan that I had built and, at one time, planned on using. It is pretty high volume (wide with a kick-out) and has multiple trap doors. I would let you have it cheap if it will fit your car and is something you are interested in. I'll snap a photo so you can see if it might work. Dry sump systems include a pump, pan, reservoir tank, and lots of plumbing. It takes a little planning to find room for everything. You will need at least a four-stage pump (3 scavenge, 1 pressure) to be reasonably effective. One solution to the space problem, albeit expensive, is the Dailey "Signature" series pump/pan combination that tucks things in tight and eliminates pan to pump scavenge lines. That is what I finally chose. In any case, clearance around existing motor mounts, headers, and perhaps front steering components can be a pain.
I've had similar experiences with my '69. Rarely do any fellow (but later model) Corvette owners bother to say Hi or visit while I'm hanging out prior to the first track session (It certainly ain't because my car gets lost in a sea of early Corvettes in the pits.). No proof, but I suspect my antique is being classified in their minds as a moving chicane. After the first session there's frequently a couple of those guys stopping over at my pit area asking questions about my car. With stock bodywork (and therefore tire size) I'm never going to be the fastest car out there, but with 400-700 pounds less vehicle weight (but comparable power to weight of most any of the cars there), I can do a bit more mirror filling than most of them are comfortable with.I feel your pain regarding the attitude of some of the younger crowd. They buy performance and think they are the experts. I road race, but the crowd I run with isn't interested in my old, modified Vette - maybe they will change their mind when I eventually get it on track and do some serious spanking. I think that is the only way to get their attention. Even the more purist Corvette guys still give me a hard time for cutting up a classic. LOL A dry sump is a good idea, but fairly expensive. An accusump can be a crutch for the long sweepers where the oil pressure drops. A dry sump doesn't help low oil pressure at idle unless it is caused by low oil in the pan after running and braking hard. I looked for photos of the underside, front of your oil pan to see how much clearance you have behind the harmonic balancer. I have an unused Dan Olsen BBC road race plan that I had built and, at one time, planned on using. It is pretty high volume (wide with a kick-out) and has multiple trap doors. I would let you have it cheap if it will fit your car and is something you are interested in. I'll snap a photo so you can see if it might work. Dry sump systems include a pump, pan, reservoir tank, and lots of plumbing. It takes a little planning to find room for everything. You will need at least a four-stage pump (3 scavenge, 1 pressure) to be reasonably effective. One solution to the space problem, albeit expensive, is the Dailey "Signature" series pump/pan combination that tucks things in tight and eliminates pan to pump scavenge lines. That is what I finally chose. In any case, clearance around existing motor mounts, headers, and perhaps front steering components can be a pain.
at this point, it's my talent that limits my car. As you point out, weigh less, more hp and I have tire sizes that are actually wider then theirs. There is a part of me that wouldn't mind someone else shoeing this car for me... I like building them, however, I don't think I'll be a better builder if I don't stay in the driver's seat for a bit longer.I've had similar experiences with my '69. Rarely do any fellow (but later model) Corvette owners bother to say Hi or visit while I'm hanging out prior to the first track session (It certainly ain't because my car gets lost in a sea of early Corvettes in the pits.). No proof, but I suspect my antique is being classified in their minds as a moving chicane. After the first session there's frequently a couple of those guys stopping over at my pit area asking questions about my car. With stock bodywork (and therefore tire size) I'm never going to be the fastest car out there, but with 400-700 pounds less vehicle weight (but comparable power to weight of most any of the cars there), I can do a bit more mirror filling than most of them are comfortable with.
I still can't believe how blessed I am with this shop. I have 5 projects going on simultaneously... and don't have to move anything when my ADD strikes.me thinks big shop equals big clean up time....it looks good.
I kept pushing that corner - never did find the limit, thankfully that one doesn't have the 'jump off a cliff' issue as where I went off rather you'd just spin off into the infield... that track would be a blast as a home track... I feel like either PIR or Pacific Raceway are my home tracks - both are nowhere near as technicalFantastic action shots! I bet that off camber corner really throws your guts for a loop. I'm really looking forward to seeing how your MPFI system comes out too.
I'll measure tomorrow, but I have a lot of room under the pan because of the C5 cradle... and that.... leads into my question in the next postFinally got around to going to my storage unit to get the Dan Olsen pan for photos. Take a look and see if it is something you can use. It is 7" deep and has baffles and trap doors under a windage tray to control oil under cornering and braking. If you are going to have any clearance issues, it would be at the front of the pan, depending on steering components. It also uses the small Tilton-style starter.
View attachment 55242View attachment 55243View attachment 55244View attachment 55245View attachment 55246
