The Camaro irs looks pretty compact. If you had a spare frame, mocking it up would be easier, or even somebody’s junk rear frame (they show up on CL now and then). Plus upgrading it later on would be easy(hammerhead, etc.).
If you plan on a roll cage, hacking parts out of the frame is less of a structural issue.
can you alter the track by using different offset wheels?
i just adjusted the ride height on my C5 that front end is certainly easy to work with
I respect what vette427 has done on his Vette, and would love to design my own but my learning hasn't hit that point (heck, I'm not even sure I see the mountain he's climbing yet) so I need to copy what the people smarter than me have done... with that said, I'll put this out there to hear thoughts. I'm thinking of just using the a-arms, springs, loaded spindles - but swap them side to side (making them rear steer) and use the stock steering box. Then I get the width, geometry, forged control arms, brakes, unitized bearings but don't dive into figuring out steering.... probably something painfully obvious, but it's my current thought.
Just throwing this out. IIRC the C4 front knuckles have the spindle positioned slightly rearward of the knuckle/balljoint centerline for caster purposes. My understanding is that this feature would be a disincentive to converting a C4 suspension to rear steer.
I'm not familiar with C5 and later suspensions to see if the Corvette group did a similar thing to the C5 and up pieces. Given that Detroit Speed has done a rear steer C5 conversion, my guess is that the C5 spindle is centered.
I welcome any corrections to my understanding of these parts.
phewwf! Just went through all 25 pages! Your progress is too fast for me :crylol:
Touching on the camaro IRS... Go for it, but definitely get a junk frame to fit it to first. I regret pulling my car apart to do this when I could have just gotten another frame and kept driving it. Also way easier to check for fitment. Drive it sooner than later, it looks like its going to be a blast as is
Oh, and Im not even sure I see the mountain that Im crawling up lol
at some point you've just got to ask yourself if you have time to do this - or in this case, is it worth it.edited The hood I bought is flat, so I need to cut all the supports and put the part that rises at the fenders then refiberglass.edited The scoop needs to be lengthened.edited All of these things I've done.... but I simply don't feel like it... so this is happening
