New injectors... the only thing you need to know about these is you must replace the lower seal with a smaller one - otherwise they fit perfectly
I should have bought a tractor first...edited
gas tank, I don't know what I'm going to do yet.edited I have the tank that is for the Fiat and already has an aeromotive fuel pump in it.edited This tank I could make work, nowever, because it's less than 7" thick, an in-tank pump is a tough fit.edited Because it's a wagon, the tank is different (side fill v. rear fill for the cars with trunks)
problem 1 with the rockers... there is not even .0015 of space between it and the rear wall
but if you grind just a bit off.... it fits
and interference fit between the ICT bracket and the no-name valve covers
fixed
then fix the fit between the alternator housing and the covers
installing the ps pump
onto the intake lots of ports, not all needed
injector fitting
hard to see, but two, different sizes of o-rings (the blue is the smaller version)
top pops in nicely
and getting closer
