Plastic Fantastic 2
well, back to this.... got most of the parts in - still waiting on window motors, but outside of that.... I think I have everything
I convinced myself this car was worth a Dakota Digital package... which almost didn't happen courtesy of that company we called FedUp
in other news, I wonder at why I had all sorts of pressure when I built this and very low pressure now...
well, if the distributor moves up....
yep, God was watching over me
and oil pressure
locked in place.. forever.. just like before
in other news, I have shaft rockers for this - and the rockers seem a bit loose
Onward
a lot of tonight was change the oil and cut the filter.... it looks okay - no big chunks and about normal for a first-fire oil change
then remove the other gauge stuff for the new gauges
then install gauges in the bezels
old
new... and more breakage.
new
and the center stack
new headlight switch
pw switches
mirror, minus light
how to wire the doors
use picks to press in on the outside of the brass ferule
pull out to get loose of housing
note the silver mark - I mark the wire and its attendant hole so they don't get mixed up going back together
remove the housing
remove from the wire guard
there is a hole that lines up with the hole in the door... feed into the door jamb
feed the wire through the guard then into the door
snap the wires back into the housing
and then install the dust block
then onto wrapping sidepipes...edited
the stainless is growing on me
I used DEI wrap, then used two exhaust pipe clamps to hold either end.... that ain't goin' nowhere lol
time to show the result.
the metal band is over the DEI wrap
right next to it is 215 degrees
I had to adjust the front band to be sure it wasn't touching the bit that's 379 degrees - because heat does travel... that said, I may still paint "HOT" as a stencil ... stylistically I won't like it but I don't want to see someone get a nasty burn
to be clear, the point of the wrap is to prevent me or a passenger from getting burned getting in or out
then I worked on the power window motor... it's toast
note the step where the brushes ride...
hopefully the new motors will arrive soon - been patient because Zip was a lot cheaper... but time's up.
lights.... work
now to wire the linear actuators... there's a possibility that I'll either be buying more actuators or that they "only adjusted at the factory" means "only adjusted at the factory unless it goes to Aaron"
in other news, starting to get the interior sealed up as well
Installed rear bulkhead
carpet
old stuff makes a good pattern but smells terrible
glue new pieces together
yum, fresh carpet smell
lots of fitting
also got the plexiglass rear window
some parts came in for it - I worked on my gas powered air brush compressor until I ran into needing parts... but had a few minutes to get a bit further
the short story - I have friends who transport medical personnel for free to the Bolivian highlands where they provide free medical help and air ambulance services to the people who live at the top of the world. They need to lower the weight of their equipment, and right now that's a 20lb air brush compressor and a 50 lb generator... this is 15 lbs. They asked for help, and I guess I was it (bottom of the barrel if you ask me)....
back to CC (Corvette Content).
some parts. Ordered 2 lenses, got 1
and fixed this... oops
in the spirit of breaking warranties....
I took this apart to see how hard it was going to be to limit its travel.edited Initially I was going to put an external switch... no need, just need to shorten a bit inside... but more on that later
this should give you an idea of why less weight is important
[ame]https://www.youtube.com/watch?v=gtoDt-82g5E[/ame]
wow i cant decide if thats exhilarating or terrifying...kind of like the scene in Ford vs Ferrrai with Henry Ford crying in the GT40
that strip is at 13,000 feet.... terrifying. I have friends in the STOL community, all of them speak with admiration at where he flies.... I have a video that I can't share but it's where it nearly ends his career on a takeoff. We joke that our guardian angels are never bored.
continuation of breaking the warranty
clever - now to figure out how to shorten the push
and my most favoritest job ever... not
and finish work on the panel (cover the holes)
it would have been nice if this set of instructions had been included.. ah well, fortunately it's really expensive and they use FedUp
Insurance company pictures
still waiting for some random parts and now looking for a door trigger rod... ugh!
thankfully my '40 started acting up so I have yet something else to do
I think I missed something on the linear actuators. Are those for headlights? Part numbers? Sorry to be obtuse, can't see where you discussed them before...
onward.... got a late start, and moved pretty slow, it was 20 degrees hotter than normal....edited
first things first, throw some paint on a place they didn't get.....edited
