Plastic Fantastic 2
Those hood louvers are just asking for an Arduino sketch and a servo motor (maybe an under-hood temp/pressure sensor too)! I've delayed jumping down that rabbit hole (although I have a complete kit and some sample sketches) 'cause I really need to make some progress on the 'vette!
you are not wrong.
as discussed before... rubbers
the most important is the one at the top of the radiator, without it and cooling is likely going to be an issue
onto metal work... radio block
headlight motor bracket
they will work, but I may remake themedited
basically it bolts to where the vacuum canisters were - next up, maybe remake and arms
light work
another view of the setup
kind of the goal
new springs
time for pottery
the MSD boots can bend... but not enough
need to cut the bottom so the rod can go back and forth
onward with door panel replacement
You can $200 by reusing the internal garnishments.... that's per panel
the door lock plate is an exception - it requires being cut off then reattached... I used epoxy
looks lots better
still working on the motors
more fixing
how to test if the switch has failed
new switch
the old broken one... looks new... it was... it would allow zero volts occasionally when the switch was in the run position...
I'm not sure I'm thrilled with this yet.... but ground some clearance
So a bit of backtracking.edited When I did the suspension, I was loathe to spend for new brakes, new brake hoses or even a new, adjustable proportioning valve.edited The suspension works well so time to color in those spots
I was close on the holes on the front spindles... time to fix that
rear is easier - need to turn the rotors to get the glaze/rust off then new pads
the wiring issue.... plugged into acc2, moved it to the same blade as the ignition...
then moved the fuel pump up to an always on blade - it's controlled by the computer, this is just the power to the relay
onward
some of the parts arrived for the brake balancer
would you look at that?
seriously, would you look at THAT!
mmm, shiney pretty
hopefully I can wrap out the brake upgrades by Tuesday - fingers crossed
I'm not "there" yet, but your efforts give me an approximate timeline and pseudo parts list to work with as a guide. Expect it will take longer than you.
:thumbs:
:thumbs:
My goal is by first snow to have this done.... there's more then a little sarcasm in that estimate.
I've got a real shot at making it before the first snow - in Phoenix. May not occur this year. :drink:
Pappy
finished up the line install... waiting on the spindles
minor fix to the headlight
such junk, 40 year old plastic.. smh
spent a few minutes resolving the pop up issue... simple fix
and also an alignment problemedited
just a bit of bend and no more binding
not a fan of them rolling the wire up
easy enough to flatten with my rollers - however because the wire isn't welded, it can shift (wear gloves)
Hmm
more hmmm
