SuperBuickGuy
did 2 things today... first, I fixed the horn
I bought a pigtail for a regular GM column.edited the system in the C3 is maddening because it relies on a pedestal to maintain contact - downside is putting it together, you're more likely to cause the push bit to come apart then you are to actually get it together.... this solves that problem
![xesgBYFh.jpg xesgBYFh.jpg](https://data.vettemod.com/attachments/50/50818-7b053ee8085793a142190e9234245e51.jpg?hash=ewU-6AhXk6)
left is the stock set up, right is the replacing wire
![xkEiQeah.jpg xkEiQeah.jpg](https://data.vettemod.com/attachments/50/50819-354ea09e3e5b4031ef586795b2d3c372.jpg?hash=NU6gnj5bQD)
use the spring from the stock set up and lock on the new wire (cut the spade end off to assemble)
![rkid3QVh.jpg rkid3QVh.jpg](https://data.vettemod.com/attachments/50/50820-44b3ab6ab93a1c457269ce0a62ff690a.jpg?hash=RLOrark6HE)
I'm too cheap to buy spacers so some 1/4" vacuum hose became a spacer
![Sfo1hMMh.jpg Sfo1hMMh.jpg](https://data.vettemod.com/attachments/50/50821-a42a86f12346320116636542bdd02548.jpg?hash=pCqG8SNGMg)
the offending stand
![PrEmfYPh.jpg PrEmfYPh.jpg](https://data.vettemod.com/attachments/50/50822-bd9e1ec15cd57bf7f098affcc07db764.jpg?hash=vZ4ewVzVe_)
now a spade male end
![cDYyeezh.jpg cDYyeezh.jpg](https://data.vettemod.com/attachments/50/50823-7b65c3dffdffdc342d5c49a2667f8742.jpg?hash=e2XD3_3_3D)
on to alternators.....
key off, voltage present
![Nb1zXUbh.jpg Nb1zXUbh.jpg](https://data.vettemod.com/attachments/50/50824-549f405f459750f733061a9097a76f56.jpg?hash=VJ9AX0WXUP)
key on, full 12v (the brown wire - which should have a resistor in line)
![67pSe0zh.jpg 67pSe0zh.jpg](https://data.vettemod.com/attachments/50/50825-dcf9151e7933a099539c0f915c3767a2.jpg?hash=3PkVHnkzoJ)
the fix is simple, a one-wire alternator.... and now we know why I kept losing alternators.
the offending stand
