SuperBuickGuy
I tested my tire temperature device, did a baseline and outside one tire a bit over inflated (36.5 v. 32.5)... all was well.
Holy Crap! Hope you didn't get full charged for that job!
yikes reminds me of the guy who was so scared of scratching his newly painted cars mirrors when he was backing it out of the garage he forgot to put the hood down, and it was a C3
on those degree plates are the degrees are relative to each other as opposed to giving an independent reading for each plate? how do you center them to the car, cars frame and the back wheels? is there some big X measurement you make to square then all up?
...That corner would be a good place to show off your drifting skills. LOL
Yeah - - Generate some Throttle-On Oversteer to bring the b1tch around...
If you are still trying to fix the understeer in that tight corner at the end of the autocross course, you need to see what your steering angle is during that turn and measure the total toe with the wheels turned that far. If the toe angle between the two wheels is great (more than needed for that turn radius, less a little allowance for scrub angle on the outside tire), then adding toe out to your static toe adjustment actually hurts, rather than helps. Toe out will make the car feel better on turn-in for "normal" turns like road course or autocross, other than that one sharp corner that you are encountering. If it were me, I would adjust for the 90% of "normal" corners and just accept the fact that the car will push in the one corner that is causing you trouble. That corner would be a good place to show off your drifting skills. LOL
when I change to a 200tw tire, I wonder if it might be useful to see if I can fit something a bit wider on the front... the biggest issue at the moment is that I have no extra clearance on the outer sidewall and the fender... maybe when I'm rich, I can get custom offset wheels... of course, as my wife would suggest, if I stopped racing; I'd have the funds to do such things .... :crutches:
I've never seen this but, don't tires have an optimal unit area load? So making the contact "patch" area bigger (with a wider tire) could actually decrease traction (with a smaller unit area load)?
I liked the change in cornering when I put wider tires on the front (same with as the rear). But that was just cruising around in Fl.
With that c5 front end, there should be lots of info out there for you.
I think someone said c5z road racers were switching to C6 front end components. I’ll see if I can find that.
