Nice trick from Mark Saveske; Once you figure out the number of shims you need for AX vs street. Tie the AX shims to the cross member - That way you can drive to the course, and do the setup there. No big deal if you are going to put on a trailer though.
Another thought, if you can and the space (and admin) allows, at the AX location - see if you can set up a Turning Circle. Take a big piece of chalk or spray paint (the marker kind) and a 100 foot tape. Could make everybody better knowing their understeer/oversteer. Better still, if you have some data analysis you can extrapolate g-load too. Or, if you want to keep it a secret, use the high school parking lot. Mind the coppers!
