Polished TPI $500 plus shipping
donnie_19
Troy, MO
Sold on Ebay. Includes. Complete wiring harness, control box, distributor, and oxygen sensor.
Lower intake. For 55/86 early bolt pattern. Or 87/95 bolt pattern. Will not work on the vortec heads that do not have the four center bolt holes. Powder coated black Fuel rail. Polished rails, powder coated lines and hardware. Good regulator diaphram, New orings installed.
Runners. Completely polished. Plenum. Polished top and sides. The bottom and the right side below where the runner bolts on is not polished.
Throttle body. Rebuilt with new gaskets top and bottom. Rebuilt throttle shaft. Polished with polished iac housing and polished top plate. New stainless screw top and bottom. Dis cover. New polished Injectors. Used 22 injectors New Complete stainless bolt set. Does not include intake to head bolts.
Sensors. Used tps, iac, air intake, coolant temp and map sensor and bracket for the 90/92 models
