OZgreen69
I have started on the R&P setup, not being the most patient customer I already dread that job !! Anyway..
Reading from other forum posts ,making notes and copying with no shame good ideas, I did this, a rig to give more resistance when turning the R&P and improving the marking of the pattern on the teeth.
So then I started.
I use the original pinion shim of .025 and the pinion preload is quite free like 7 Inch/lbs.
.229 shim on the left and .2385 on the right
Back lash of .006 to .0065 , and this is kind of my first reading.
And on the another part of the ring
Now.... I thing that on the drive the contact is not bad, but on the coast I am a bit lost here !! Too low maybe ? Not enough back lash ?
If Gary can join the party, I will be more than happy.
Thanks in advance.
So then I started.
Thanks in advance.
