Twin_Turbo
Der Maulwurf
- Joined
- Mar 5, 2008
- Messages
- 7,575
Some more done, fabbed a mounting face for 3 gauges to go where the radio was. The power and illuminatiion for the gauges is pulled off the radio harness so no loose wires or scotch blocks anywhere. I like my wiring clean.
I have 3 gauges but decided that the wideband commander 2 has to go on the a pillar because the gauge doesn't match the other 2. I'll get an oil temp gauge instead and wire it w a switch so I can switch between engine and tranny temp.
This is going to be my filler cap. Needs a custom ring machined and some cutting & welding to the quarter panel.
Got the valve covers on. Took a bit of modifying to fit. These are the only covers I have that fit without hitting the rockers or guide plates. i did have to trim the manifold side inside edge of the covers to get them to sit square, they were hitting the guideplates. Also had to notch the dr. side to be able to move it under the washer pump and not break off the pump pipe
Mounted the 2 bar map sensor here (it's for the boost retard):
Wrapped the exhaust pipe that runs past the sump & starter
and..it's running
still NA as I don't have the intercooler piping finished yet but still, it's a big step that it at least runs
[ame]http://www.youtube.com/watch?v=-KOpmXbppjc[/ame]
and..it's running
