OK more progress on the 82 TA. I was going to install the mockup LS1 and T56. Didn't quite get it done.
First I installed a remote bleeder setup on the T56. This is from speedwaymotors. Also plugged the reverse lockout hole and the cags solenoid hole. Don't need that stuff
Then I found out that some of the bolt holes on the T56 bell are stripped and the others aren't perfect either. I may have to get a quicktime 8020 bell. Crap!
Well, let's install the motor first then... OK, trans dapt 1" offset mount plates. They come with bolts and nuts, the nuts are for on the back of the plates to provide more "support". What a load of hoohah.... they only fit in 1 of the locations. In the bolts bin with that stuff then. Also had to notch the dr. side a little or it wouldn't even fit the motor because of a casting bulge with a machined flat (most likely for maching track system)
So, the plates are mounted...time to stick it in. Batwing pan won't fit, next to impossible to install. Need new pan too then. Crap!
So let's just lower the engine in place... Pass side bolt goes in, nice...over to drivers side.. CRAP!!! again!!!!! This stuff doesn't fit. The motor mount adapter plates are probably made incorrect with the mounts sitting too high, spreading them apart. The engine also sits pretty close to the center link. I couldn't even get a thinner bolt in there properly. Crap crap crap...more problems, last thing I need is more probs. I'll have to do some grinding on the moroso solid mounts, I had to modify the 3 holes on them already to be able to bolt them to the trans dapt plates. Should have been worried with these plates since they came with a cheap rattle can paint job. I had them plated. Next time I'm using a different brand, that's for sure.
I installed some 14" rear discs, I'm not 100% sure I like having larger rear rotors than fronts.... hmmm....
The black wheels from my iroc fit with a small spacer for added clearance
front
rear
The rear springs I got from Vogtland are probably wrong... they have pigtails on both ends, are pretty short and don't sit tight around the puck on the axle. Something is not right. Haven't gotten confirmation off the part # yet. I do know that my old set that I put on my buddies car because mine was up on the lift and his needed work anyway...they were different. They were pigtailed on one end.
the front now has me worried too, the others didn't have so many progressive coils up top and on these the upper 4 coils almost touch and the springs are now very stiff. I had to really squeeze them to get 'em in. Let's install wheels then and see where it settles. There's no engine or trans in the car but it sits ridiculously high. I don't see it coming down all that way. I stuck the LS long block in and it only dropped a little. CRAP!!! Looks like even more trouble.
Yuck!!!
Something must be wrong about these springs. I can probably cut 2 coils off the top. I'll check w/ all the weight on the car and will determine what to do then.
This is the rear with some cut stock springs, the same that were on there in this pic
compared...the rear will settje like it did with the black springs.. The vogtlands are shorter and because of the 2 pigtails can not use the isolator. Ugh...
I think I will have some bolts left over when done LOL
Now a photoshop of the wheels with a low car..
This is how it should look, not the gasser look above
