C3 Corvettes have a suspension that dates back to the mid-60s.... at the time, they were ground breaking, now, they're just breaking.
In the Corvette world, there are two major companies with different rear suspensions - Greenwood, and Gulstrand (latter not a company, but a design). They both look roughly the same - but they both were designed for racing in specific classes. They were/are quite successful - however, after a bunch of study and a lot of review, I'm going to try something a bit different.
This isn't a drag race 'vette, nor is it an SCCA car - rather it's a car that's transportation and the occasional autocross.
So here's the suspension as it sits
composite spring - 420#, adjustable lower control arm
The reason for the update now is this car is flat out scary because (probably the left side) clip is missing in the rear diff... the problem is the driveshaft is the upper control arm. For Mr. Polyester - that's fine, but having an upper control arm that moves 1/4" to adjust for suspension travel is not something that is pleasant to drive in its perfect condition....
So the update is to put an upper control arm in place. the question is.... how much camber gain should I have on the rear wheel? (that's set by the difference in length between the upper and lower control arm).
I'm rebuilding the trailing arms - while I'm at it - but the bushings look to be 40 years old and I have johnny joints to replace them
