Suburban burns oil. Rings or valves?
VegasJen
Formerly Known as Clutchdust
In transition
My 1994 burns oil and fouls plugs. There's 204k on the clock but the real mileage is anyone's guess. I got it for cheap because the PO overheated it and cracked both heads. I bought a pair of used junkyard heads and all I did to them was put new seals on. I freshened up the bottom end, put in new rings (cylinders were pretty clean), bearings, timing chain and oil pump but otherwise it's still pretty much stock.
The thing is I know it's burning oil, around a quart every 1000-1500 miles. It runs pretty well but when I idle for any length of time, like at a long traffic light, it runs pretty rough for the first 10-15 seconds of acceleration. After that, it runs as smooth as you would expect a 20 year old, 200k plus mile engine is going to run.
My guess is the valve guides/stems are worn and it's pulling oil past at high vacuum. Is there a way to check this theory? Any other suggestions?
wouldn't a leakdown test where you put a little oil in each cylinder tell you this?
