Take off SBC parts for Sale
donnie_19
Troy, MO
I can send additonal pictures open to offers.
Stan's Tri Headers, purchased new 2 years ago and had them ceramic coated. Their coating didn't hold up so well. New I paid over $700 sell for $350 Some surface rust on before the collectors.
Chrome Oil Pan $30
Chrome Valve Covers with hardware $25
Chrome Air Cleaner with drop down $25
18 1/2 fan with clutch $35
Flex plate no chipped teeth $35 new last year
Chrome water pump $20
Weiand Manifold $50
front half 1/2 of the valve, hoses were purchased new 2 years ago $50
cylinder & frame bracket $50
Power steering gear box and pittman arm. $50
plus shipping
TPI Polished INTAKE SBC $550
This sale Includes. Complete wiring harness, control box, distributor, and oxygen sensor.
Lower intake. For 55/86 early bolt pattern. Or 87/95 bolt pattern. Will work on the vortec heads just enlarge the four center bolt holes. Powder coated black Fuel rail. Polished rails, powder coated lines and hardware. Good regulator diaphram, New orings installed. Runners. Completely polished.
Plenum. Polished top and sides. The bottom and the right side below where the runner bolts on is not polished.
Throttle body. Rebuilt with new gaskets top and bottom. Rebuilt throttle shaft. Polished with polished iac housing and polished top plate. New stainless screw top and bottom. Dis cover. New polished Injectors. Used 22
Bolts. New Complete stainless bolt set. Does not include intake to head bolts.
Sensors. Used tps, iac, air intake, coolant temp and map sensor and bracket for the 90/92 models.
Change of direction and going with LS swap.
