verify my planning plz!
cajos1968
Leiden, The Netherlands
Guy's
I have the following in order in mind for coming weeks. Is this correct or should I change the order?
Engine (454) is out!
Clean up/paint engine compartment.
Connect transmission to engine
## Paint engine (done 11-12) and transmission (on hold).
New wiring engine compartment
** New front suspention bushings
Rework/install headlights.
Install engine and transmission.
Install radiator
Install engine and compartment components
Install rack and pinion
Lower the car
Continue Interior
Continue exterior
I would finish the paint before anything, certainly before the interior....
and really , done before the engine is in there makes it easier also, but it's not mandatory....yet another thing about my paint quandary, too much work....
:eek:
:eek:
You mean, slapping paint on the body?
Like this?
Thats done ;-)
Damnit man, yeh, I saw that.....me jealous, wanna swap bodies???
I too, I dunno, tired or depressed, or whatever to be tearing into the vette body, it need paint something fierce, but I just don't have the charge in my pants to just DO IT.....and getting it done is a fortune....
maybe I can go to MACCO for a guesstimate....they shoot paint all damn day....
I had some luck a mate of my brother did this one. Cheap also. I have to say that if you make an appointment to bring it in, the force to finish it is great.
May the force be with you :noworry:
I didn't paint my trans. Only cleaned/rebuilt and buffed.
You might want to think about the heater core. If it needs changing, do it before you reinstall the interior.
Nice paint job!
I think I would position the R&P before you pull it, and finish it while the engine is out of the way. (Just me, never done it). I am also an advocate for finish paint LAST. Less chance for damage that way.:drink:
That is one of my "doubts" I would like to install it first but don't know if it is possible to place the engine then. I would like to install the engine with the tranny mounted.
Anyone with experience with this?
Regarding painting, the dollar (vs. Euro) dropped couple of months ago, so I took my shot to buy the Keisler set, unfortunately the car was just painted.
When I had my body repaired and painted, the body shop would not do any prep work on the front end until the engine/trans was back in and the car running. Engine/trans was rebuilt with a new clutch/flywheel. They installed my BB with the trans mounted. They had it in no time without problems...but then again, they are experts at it.
r/Pinion is easy to install with engine in place, not a issue, for one thing you have the headers mounted and so can see the clearances necessary ....
not that much of a job, really...
once you know i'ts the '92 Grand Am rack that is....I had a hell of a time finding that out years ago....
:bounce:
I installed my R&P with the engine in the car. I also recently pulled the engine with the rack still in place with absolutely no problems. I even have a 7 qt. Moroso pan.
Guy's
Install radiator
Lower the car
Continue Interior
Continue exterior
Look at Karstens' pix above really careful and you see that shark is a easy 2' off the ground in front, and you can also see the engine barely clears the rad support going in, and that's a small block, I have typically found a very similar situation and have given up on doing them together, finding it much easier to do the tranny, then the engine.......
:smash::bestwishes:
