What if....
I have owned several diesel trucks over the years. And they all had HB brakes. I don't like them. I think the vac brakes work better and feel better.
Fkn hate mine too. On both of my diesels I had to replace that godawful POS because it leaked all over every thing. Now on my 1-ton gasser as soon as I get the chance, I'm putting a vacuum booster on it (I just wish I could see GENE's head explode).
:crylol: that would be something to see.
What about an EVO valve?
Make it work past 25mph and you got best of both world. no?
Well, weight saving put aside, of course.
Someone needs to make a controller for the EVO valve. Certainly would cure a lot of steering problems. This is a Delphi document that explains pretty well how it works.
CRS sets in, I seen/heard of these controllers, but what sort of problems it cures?? my serp conversion, I fit the stock '72 brass valves into the back of the '88 vette pump, just to hook up the line, then when doing the rack some ten years ago, I cut the ends and spliced them, right off the pump, same valving setup......same trick for adding the HB setup, not a issue in the world with any of it.......what can that valve do for me???
:crutches:
:crutches:
The EVO valve is is a solenoid that pulses at higher speeds to reduce steering assist at speed. So your steering goes from full hydraulic assist at low speeds like parking to little or no assist when you reach a certain speed.
There is a Ford system that is essentially the same that uses a stand alone controller but I think it might be easier to make a controller that uses an accelerometer for speed sensing.
Cool, the PDF explain between which speeds to interpolate.
From what I could read here and there, EVO take a PWN signal to modulate and I know at some point I'll have a dedicated microcontroller to deal with those kind of things.
Anyone know from which car I you could pick a EVO valve that would fit the Corvette ps pump?
:crutches:
It gives plenty of assisting at low speed, nothing at high speed. So no more risk of locking brakes or steering too quick when on the highway.
For you, it's the only device that could save your hydrobooster soul and
pride.
:crutches:
pride.
Ummm hummm....my car drives just fine, thank you very much....:smash:
Below is a picture of the EVO valve (w/ Standard valve on top).
What car are they from? I see them on pumps from mid 90's GM products like Olds Acheva, Grand AM etc. Some Saturns.
Also, as far as hydroboost, the EVO valve wouldn't have any effect on that.
Here is the catch with the EVO controller. You don't want to reduce pump pressure, at speed, while turning the steering wheel quickly. You will get what is called pump "catch up" where the wheel feels like it hits a stop. All of these systems use a steering wheel rotation sensor to detect that. Thats why I thought a 2-axis acelerometer would be the best choice for the controller.
I have a ton of information on this if you would like to pursue this. I talked to a retired Ford engineer about this and a Delphi steering engineer. They gave me lots of info.
Other than a possible MPG increase measured in the .1% region, I really can't see anything there....damned if I know WHY, but I LOVE the feel of my car at speed or in a parking lot, I guess maybe someone on a autocross maybe able to point out deficiencies....but seriously, I a reasonably quick street driver, never a over reaction at speed, never a problem with wheel tug or braking.....and besides, the overall steering ratio is the same no matter the boost, so I fail to see how that affects anything....except 'road feel' which to me is fine....:eek:
I was about to ask why, but I rather did my homework.
http://forums.corvetteforum.com/c3-...wer-steering-flow-control-jim-shea-alert.html
http://forums.corvetteforum.com/c3-...e-know-how-a-hydroboost-works-internally.html
Looks like you had the same questioning 6 years ago and looks like you didn't pursue the idea, should I understand it's a dead end?
According to Jim the great, EVO valve modulate the flow and not the pressure to achieve its role.
Now I bought this things in the hope I would get better feeling in my steering and braking :
http://www.borgeson.com/xcart/catal...re_Reducing_Shim_Kit-orderby_0-p-1-c-133.html
Is this kit mis-labelled and should be called "flow reducing kit" or is it acting on the system in another way.
May reducing steering and braking assist level like pulling the rope from both ends?
Frankly I'm lost here.
PS: Michel, you don't mind I derail further the thread, it's for the good :sweat:
this is turning into a great discussion on evo valves and pressure reduction at speed.... let's see where this goes and maybe we need to re-arrange the thread, it sure isn't searchable with the title "what if"
:friends:
I dont mind at all, I started this thread to start a "good discussion" about manual brakes.
I'm not convinced at all that HB is the only way to equip or modernise our C3.
Like I said earlier, I had a few cars with unassisted braked and I recall having no problems stopping with them.
Sooo now, in 2012 I'm wondering if having a set of good lighter binders and a manual new master wouldnt be a better deal for me.
A few answered about what they felt about unassisted brakes and I'm happy with the answers.
And by the way, it's turning into constructive discussion about HB.
Your right Karsten, the tittle dont lead to brakes.... my fault, I'll try harder next time LOL
Well, we're just a couple of post deep into the subject, we could start another thread without too much hassle, I could compile the existing discussions in the first post.
:crutches:
pride.
I'm with Gene on this one. KISS method
I just looked at Rock Auto's catalog-
They list 2 master cylinders for 1969- the NO power brakes m/c lists a 1" bore, while the WITH power bore size is listed at 1-1/8".
From that, the math is pretty easy- 500psi x 1"= 500psi. 1-1/8 x 500psi = 562.5psi (500psi is an arbitrary number, but hydraulics is hydraulics)
Not a whole lot of difference. And in those days, power brakes WERE optional. And past the master cylinder, nothing else cares. Proportioning valve, lines, calipers, and pads are the same.
The old real rod operated mechanical brakes- adjust them, go for a drive and stomp the pedal- if it takes off left or right, or swaps ends, keep adjusting.
Something else to consider. The pedal lever ratio for power and manual are different
Manual 1" master dia. 5.5:1 pedal ratio
Power 1.125" master dia 3.5:1 pedal ratio
Remember, those m/c numbers are bore diameters, not bore area. The area ratio between them is 1.27x.
My 68 BB (sold) had factory manual/unassisted brakes. It would lock up all four tires in an emergency, no problem. I have been thinking of going unassisted on my current c3.
Thanks. Is the factory pedal drilled for both?
