1969 427 restoration from Sweden
The gear box console and parking lever console is brand new. The old units were basically beyond reparable condition.
Very pleased with the quality of theese parts! Nice fit and finish.
The shifter console also had to be renewed and the new unit fit perfect.
It was a very nice feeling to be able to test shift my new gearbox sitting in the car! Nice short throws.
The old rear luggage box assembly had to be restored. Basically new parts were put in. I did make a bit of the work myself as well, for example the luggage doors. Machined them out of water proof plywood.
Finished with new carpets, plastic frames and lock mechanisms.
Repainted the complete interior. The plastic and vinyl parts were in nice condition but the color was uneven so I had to do something.
I used SEM:s product line for this. Easy to work with and a durable and nice finish should hopefully be the end result.
Time to start restoring the head light units. They were almost working when I bought the car but after the first summer they had completely given up. I now understand why...
Bought a complete restoration kit and a new seal kit for the vacuum units.
Glass blasted all parts and painted according to my own preference.
Time to reassemble!
A few more photos of the parts beeing test assembled outside the car. They have to be disassembled before they go into the car. At least I did not find any other possibility to get them back.
And finally the front end chrome and grille is back on the car again.
The pictures show that some of the chrome is in not so good condition. This will be adressed next winter.
Since the paint on the car is some 20+ years old, chips and dents can be seen. It is good enough for now at least.
VERY NICE WORK MAN!!!!.....maybe you look into new chrome on the bumpers instead of buying new from here....my last bumper sux and it came from Ecklers.....down the road from me.....
I fought the headlight mechanical restore some 18 years ago, having sketchy luck with it at best....got it ALL together and working GREAT, then to hit a damn Florida deer here on night in '98....too out both the headlights.....
:hissyfit: I was ROCKET PISSED!!!!
but at least the deer heer are small, like a dawg.....so it did not come through the windshield and kill me and the chick.....
I went fixed lights after that, not enough money to fight the war over them again, much less time/effort/temperament......:hissyfit:
Thanks Gene! I will for sure be rechroming the original parts. They actually have a very good fit on the car and I do not want to ruin that.
Back on the project again...
Restored the wiper motor and complete mechanism. The motor was in good condition. I took it apart anyway. Changed all wiring just to be sure.
Had a friend who is an electrician make some test runs and check it for me. Everything worked out ok.
Well, he´s interested in old motorcycles and Swedish SAAB cars. Here is one motorcycle he has restored. Just have to show it:thumbs:
A 1973 Yamaha 125cc. Restored completely with NOS parts all thorugh. It has ben driven 1 mile after completion. Amazing...
Back to the old American iron, it´s better than Japanese tin cans:kissass:
Machined a new sleeve for the windshield washer pump piston. Made it with a slight press fit and epoxi glued it inside the original plastic housing. Snug and tight.
The "almost" complete mechanism.
Back in the car. Very tight to assemble it with the engine in place...
Set all the wiper mechanisms as per the instructions in the AIM. Got a pretty good sweep and parking of the wipers.
Continued with the interior. The center cluster console was broken. Not an uncommon fault as I have heard.
Fixed it with a piece of metal welded together and then screwed and epoxi glued to the aluminum console.
Had to restore all the gauges in the console. Chose to buy all new gauges. Did not buy a new clock. I hope to restore it next year.
Everything ready for assembly.
Repainted the upper part of the center console.
This is a bit strange, there is an armature for a lamp in this part. Including a plastic light spreader. But, the wiring harness is not equipped with a lamp???? And if you would try to assemble a lamp with socket it will interfere with the dash support. What was GM thinking? Anyone with any info on this?
Machined a new lower bearing assembly for the steering shaft. Consists of a needle bearing and some other stuff.
Modified the original bearing holder to keep everything in position.
A new sleeve with a O-ring on the inside forms the new bearing surface on the steering shaft.
