1958 MGA Coupe
I cut the anti rattle springs although i am not sure why, they didnt look like they would hit any thing.
with a grinder and a cut off wheel
i will bend the tabs after its on the road with the real body
had little Joe make a seat bottom
hes going to have to get a pair of those skinny driving mocassins for those aircraft carrier size feet
and todays work....
made some room to work
good day today......
looks like a good match
clean baby clean
1/2 and 1/2
plan is to change the oil pump and i see no reason to get out the engine stand
this will get scotch brited and clear coated
that my friends looks like a new pressure plate
and of course the 2nd hardened gasket
typical of an engine that has been sitting for decades
looks like originalstyle pump
new pistons
another new piston, that makes 3 new pistions and one with oil stains
cleaned up
measure this tomorrow
need to do some research on this freeze plug on why its out so far, when i got the car it still had antoifreeze in it and the radiator was full and had not split.
a good day in bob land
well I took care of the spin on oil filter adapter, I modified the approach Lee Narjam took and only did the grinding to the filter side of the retaining nut, this allows the machined surfaces to be mated to each other
full face mask so icould see what i was doing and the final poisition was with the grinder on top paralell (sp?) to the wood
its now 3/16 and it took about 30 mins of just slow work so i didnt screw up
had a family holiday party so my time was limitied today....pulled oil pump off and removed pressure plate.
pump came off easy
heres how you measure it
tough to hold and take a picture
the oil pump is right at the point of out of specification and will be replaced
thats pretty clean in there considering that both the throw out bearing and clutch disk show about 1/3 wear
no ridges or grooves almost looks like a new flywheel same with the pressure plate.
so if the oil pump is just out of specs what else is going on?????
a one person show this am so this is how i wedged the crank to remove the crank nut
well that doesnt look right
so what else is going on????
pulled # 1 CR cap and this looks good the the crank has not been turned
you probably know where this is going
i think this is one of the left over front end parts it had a castellated nut on it
yeah baby thats what we are talking about
so you dont screw up
and always take two pictures of imporatant stuff......it looked really nice
on to the trans
throw out bearing pivot bolt
slightly worn clevis
looks pretty good
so heres my on the scene conclusion......some 40+ yrs ago and 10K ago they put in a new clutch,pressure plate,throw out brg and flywheel (based on a 30K mile clutch life of kids)then they drove the car until the engine started needing some help....then when it went to the shop it needed 3 pistons and this threw the budget out of whack, they replaced the 3 bad pistons and maybe the crank....cam is original and they replaced the main and con rod bearings. I know this car has good compression and i will not be taking the head off so who knows what new up there....and for some reason they had to replace the rear engine core plug
you won't pull the head? the cynic in me is laughing at you because he knows you will.... while you're in there, and while you're at it, and since it's the right way to do things.
:bump::skeptic:
:bump::skeptic:
nope not this time..... i have great compression and it doesn't burn oil, i dont have any reason to think theres a problem or an issue. On these cars the 1500cc is the first generation old dog and most guys upgrade to a 1600cc or the 1800cc engine. so if you are going to spend any serious engine money you would just step right up to the one of those and spend the money there.
:bump::skeptic:
then you will be an example to us all ;)
did some more quick clean up on the trans
in case you ever wanted to know....the trans mount has a stepped outer ring
the trans mount is soaking in PB blaster i have no idea if that works with steel and aluminnum galvanic corrision but since i did this before i am more careful with trans casings,see that nice shiny area....i broke it off by accident
So before long we're going to be seeing a bored, stroked and supercharged 1800cc in there. :bump:
when i get a chance i will link up a guys thread where he slightly modified the drive line.....this is pretty sweet
http://www.mgexp.com/phorum/read.php?2,2542209
well I didnt have any problem just work.....
hard to see but i cut and sectioned the inner sleeve with a body saw and collapsed the mount in on itself
mated the trans bracket to a socket for support and tapped the mount out
i win, remember its just metal
seems like a newer trans then should be there
cleaned
clear coated
Merry Christmas what a great day today for the family..
when the boss curled up for a little snooze i beelined out to the garage for some clean work.
started by carefully examining the trans mount bushing to make sure there were not any nicks in the casing shell and there was so i took a file to those and then polished it with 600 grit paper and oil to make sure i had a really nice smooth surface, then cleaned it really well and set it out side on a block of ice with the "press socket"
came inside and "brake honed" the trans mount and made sure there were no nicks inthe outer most part of the mount and deburred it with a fine file on both sides and cleaned it with brake clean and then oiled it up. i prestaged all the tools i would need and i put on gloves so i didnt transfer any body heat
i found the pitman arm off of a corvette worked pretty well to start the process
it was a pretty good upper body work out even with the 2' long breaker bar, i had one foot on the trans base or i was just picking up the trans when i tightened the bolt
done
and Santa was very good to me all the parts i ordered on Monday to wrap the engine/trans install up were deliverd yesterday afternoon, I dont often set timeframes but the goal is have the engine in the car by sundown Sunday.
dry fitting of the oil filter head to bend the tubing to fit
off alittle bit
just a vise and dead blow hammer
give it a little bend
done
checked specs and washed with soapy water and a bottle brush , lubed up with engine build grease
hammered down the bottom with a piece of wood and dead blow hammer on the floor
sanded and cleaned
not sure how other do this but this is what i conjured up
divine inspiration the sun shone in i did put the new tenisoner in also must have missed the photo
this really screwed with me for a moment trying to use the new one but the woodruff key wasnt long enough
didnt finish it all though before the boss came looking for me.
ready for the inner trans tunnel to get painted and an engine install
As always, this is some awesome work !!! I really can't wait to see this car on the road (well, photos or video) .... Lol...... You're making so much progress I wonder if you have the plates and drive it before I get this VW done.....
it was a good day today
i decided to paint the oil filter head to engine color
it lines up nicely and has two new crush washers
tabs folded over
torqueing oil pan bolts.....72inch lbs not much
collapsed the wrong core plug in on itself
not too much gunk
cleaned up
done
cleaning one more time
paint time
inside and outside painted
garage turned up to about 75* for drying purposes.
thks tying up loose ends
easy way to help seat the bolts
replaced front trans cover seal
pressing in new seal
new one measeured 3/16
everything went very well today
tightening trans to engine
the kids even pulled out my MG shirt from 22 yrs ago...
torqueing bolts
one trans bolt and 10 motor mount bolts
still need to get the right seal for the timing chain cover or get a new cover to match the seal i got
