1958 MGA Coupe
well time to get back at it......after contemplating a course of action for a few days I said screw it and just started cutting and welding...
I made an inner brace for the door hinge pillar post to tie the two hinge posts together and welded these bolts at the correct spacing for the brackets
this takes most of the movement out of the doors hinge post
I guess I forgot to take the heads out of the hinges when I drilled out the screws
I feel like cutting out rust today
these are just the most of a preliminary fit as you can get
some more cut lines
taking car of the inner brace
the inner brace cleaned off
lots more to do here .....but no more rust in this area
looks like anti-fouling paint on the bottom :)
io just need to add some markings for depth...
i always sand off there primer for my own....
there are probably a thousand ways to do fender patch panels, this is how I do them on fenders that have no accident damage I pair them up and brace them up together this way they are a matched pair
lap the door end
grind off primer and paint with weld through primer
now to get the right arch
With all the work you've already done on that body, I'm amazed at the amount of rust you still have to conquer. That wasn't a car, it was a pile iron oxide! Amazing work bringing it back.
thks guys i really am down to the last bits of rust repair on the fenders,and i have two areas on the body that are behind the seats and on both sides of the removable battery cover that i repaired in spots but they are so poch marked that i think i am just going to cut them out and fabricate a new panel for them. if i dont do this i think every time i saw them it would bug me. after that its maybe a few small holes i missed here and there and then its down to body filler time and sanding
oh good, the easy part - body filler and sanding. Ummm :lol: doesn't body work and sanding take twice the amount of time as it takes to do the mechanical and rust repair portion of the job?
yes but that is no brainer work.....just 30 mins a day for the entire summer and paint it in the fall.....
while I may vacation in my ADD, spending more than a few hours on anything would send me postal.... which is why I trade doing fabrication for someone else doing bodywork
I have been busy doing other things this weekend but I Just realized I hadn't been posting my efforts of the last weeks work
so I was working on the rocker sill and the rear dog leg. getting these fitted isn't hard but just takes time and effort I positioned the rear fenders where I wanted them and then tightened them in place and then used screws to mock everything up and then welded the rear dog legs in place. what you are looking for is parallel lines, the front fender can be pushed towards the back some but since I am a one man show that was the best I could for a trial fit
3 hrs tonight , we start by curving the bottom of the poor fitting piece in a shrinker
I had to reform the bottom mounting flange to make it fit properly it was not parallel
parallel lines
this is actually a nice parallel line not sure why its not showing up in the photo
it looks to me like the door needs to come up some and go back just a wee bit
time to get ready for body work ......all sanding outside........so my saw horses have to be able to go down the garage apron and on to my grass. so lets make some axles for 8" wheels, lets use 5/8" round stock and some channel angle
the wheels were on sale from HF for $6 each, 5/8 round shaft $8, angle iron $8, $8 (2) 2x4, washers and C clips $6
lets cut a groove in the 5/8 stock with and angle grinder with a cut off wheel and use a C clip
a couple of big washers
9" shafts because it was cut from 36" stock
add 10' 2x4 to saw horses
some channel angle with the zinc ground off
and voila
eating pizza and letting paint dry before I spot weld the outer sills in place.....I decided to use a weld through primer on the areas that are being "faced" together all other areas got primed and gloss black rustoleum
wire brush primer off
taped off the "to weld area" and primed and top coated
used weld through primer on areas under the tape
same treatment on rocker sill
practiced some test welds on similar stock
and I have used up about 25 mins so back out to work
well I have hit my duty cycle on the spot welder and need to take a break and let it cool off...just call me popeye that thing is heavy!!!!!
this is what factory welds look like
and my set up and welds.....I always clamped it and welded in between
back to do the top
and done with pass side, I have had enough for the day...too many fumes and too heavy of welder
tomorrow the other side
one thing about spot welders - make sure you keep a nice radius on the tips. we used those all the time (in fact, I think my dad still has a floor-standing model in his shop) to spot weld stainless hoods together.
If you don't want the divot, simply use two flat copper plates between the weld-tips.... of course, now you want the divots - but those things are really handy, so if you ever don't ... now you know.
