Dirtbuster1
It uses the same gnd as the TPS, well there may be a problem right there. Check again but with the throttle open, maybe that's the problem.
I picked up on that too. The 81 has both sensors go home.
His loose mounting of the ECM should NOT be a problem, as it's ground is in the ECM harness connector. Starting the car with the diagnostic terminals shorted would also not cause a CTS to blow.
As TT has stated, the TPS sensor may have a fault to ground, or the engine to ECM ground wire may be lifted/bad.
All the sensor wires are 1-5 volt with negligable current levels.
The output side of the ECM carries larger current values, and drive the relays/injectors, and what not. A ground fault COULD cause excessive
current thru the sensor wires.
I suspect a bad ground/faulty wire/connector.
There are 2 gnd wires on the harness from under the hood to the ECM. 1 gnds to the front of the intake, and the other under the air solenoid switch. Both ground to the intake. The intake has been painted and possibly causing some problem. It is either Aluminum or Magnesuim, I'm not sure which. Anyway a poor conducter. IT would be easy to attach a ground to the back of the alternator that runs to the battery thru the frame. I don't think this would cause a problem, what do you think. This is a #6 wire.
