MYBAD79
Moderator
Makes sense, I think it's best to make it adjustable :goodnight:
You could if you do it like BBShark.
You could also do it if you did it the conventional way, it may not be smart but it's possible but you shouldn't do it and maybe you should make it adjustable if youcan but maybe it can be made solid if you can..... :suicide::sos:
Oooh...I don't remember but it was longer (too long) than what you see there. i cut about 1/2" from the ends (that's where the flats were).
Just measure your car, deduct some for the brackets, some for adjustment and about 2.5" for the rod end head/jam nut (a 5/8 rod end has about 1" distance from the top of the threads to the center of the rod eye, adda jam nut and you're right around 1.25" per side)
I can give you a measurement tonight
I just need to drill a hole and weld a nut on one and then install it and I'll tell you how long
I think my current bar is something like 17"
You forgot the reducer bushings. If you want to use a 1/2" bolt instead of a massive 5/8 one. Or you could buy 5/8 shank, 1/2" eye rod ends.
I just wanted to save you guys some time on part # searching for the spreader bar twin turbo made. I just ordered the parts so here ya go
You can get all of the parts from speedwaymotors.com
Here are all of the part numbers needed
1170810L LH male heim joint 9.99
1170810 RH male heim joint 9.99
3159603 RH jam nut 1.99
3159604 LH jam nut 1.99
91034158-19 19” tie rod sleeve 10.99
The 19 at the end of the sleeve part number indicates the length, so if you need a 17” bar you would use 91034158-17
so you went an ordered your parts and did not even ask me if i wanted to order mine tooi'm not feeling the love anymore :tomato:
That's it no soup for you,one year :lol::lol:
