kwplot34
Heart Attack
I just sent chris a pm to see if he is any closer to sending me those brackets yet
I just wanted to save you guys some time on part # searching for the spreader bar twin turbo made. I just ordered the parts so here ya go
You can get all of the parts from speedwaymotors.com
Here are all of the part numbers needed
1170810L LH male heim joint 9.99
1170810 RH male heim joint 9.99
3159603 RH jam nut 1.99
3159604 LH jam nut 1.99
91034158-19 19” tie rod sleeve 10.99
The 19 at the end of the sleeve part number indicates the length, so if you need a 17” bar you would use 91034158-17
thanks i have been wanting to do this for a while now and with the house construction etc.....i need a small project what are you making the bracket out of? perhaps i missed the thickness...is that 1/8 or 3/16 stock
13.99 isn't exactly pro race heavy duty, real heavy duty ones are more than double that price. However, why waste money there, they don't see much abuse at all, the cheapest rod ends will do just fine.
This is the spreader bar I built for the 77 project.
It's very easy to fabricate and even easier to install because of the vertical bolt engagement. No need to wrestle a bolt, nut and some washers in the confined space around the radiator shroud.
All you need is some 1/2" UNF bolts and nuts (I used pretty round stainless allen head screws), some 5/8 UNF rod ends (LH&RH threads) with either 1/2" eyes or some 5/8 to 1/2 reducer bushings to tap in place. Also some 5/8 lock nuts (LH&RH)are required and of course the sleeve. The rod ends don't have to be super high quality. some chinese ones will do. You can get all the parts from speedwaymotors and other speedway shops. The parts are very affordable.
I used 1/4" x 1 1/2" angle. I think 3/16" would be fine also.
Let me head out to the shop and check if V-Twin's is still there![]()
I have it installed and am surprised what a difference it made. Here is a pic for you viewing pleasure.
