BangkokDean
That looks like the oddest position for a MAP sensor, down next to the headers, and what are all those vacuum hoses doing there?? I can see one smaller hose to the map sensor, but I seeing larger ones also... why??
looks like some green wires going under that bracket, and for some reason the MAP sensor looks as if the mounting tab on the outer end was broken off....that's weird....
what I would do is get another sensor, and just let it hang off the port with a short hose to the plenum, and do what necessary to get the wires hooked up correctly.....
wonder if it's heat related?? too much heat for the poor sensor, that's certainly a funky location that I see no reason for it to be THERE.....:club::amazed:
Actually the sensor is connected to the back of the engine the exhaust is at least 20 inches away.
But I will order a new one from Summit that I posted above.
What you see as hoses are wires from the Dakota Digital shiftier indicator.
