454Can-Am
Member
Wow! Very nice work, thanks for sharing with us. What running gear do you have? I'd guess it runs as great as it looks!!!
Been meaning to get back to you..................... the car has a pumped up 350/aluminum heads/dual carbs/etc. Probably 375 to 400 hp. I put a 200-4R tranny in her, so I should be able to get some decent mileage on the highway ! Got 308 gears in the rear.
Actually, I haven't tuned the motor up............. or should I say ---- adjusted the carbs good yet ! She runs so rich it burns your eyes !!! Gotta do that and adjust the TV cable on the tranny, so I don't burn it up.
I doubt if it'll do quite as well as my Can-Am. With the Tremec TKO in it, along with the 450 hp big block........... I get 20 mpg's ! When I'm going 70 miles an hour, I'm only taching 1800 rpm. The automatics never get as good of milage as the manual trannys.
Still got a ton of things to do before I drive her much......... Gotta get a full alignment/a lot of tweaking and then a bunch of wet sanding, so I can get the final paint on her !!!
Rick :beer::beer:
