I have a small compressor (10 gallons), and a HVLP gun, but I"m really afraid to use them in the garage. It's no suburb here, at the slightest funny smell the whole neighborhood will jump on me.Do you have a compressor and paint gun? At this stage I like to seal that panel with epoxy primer and spray one coat urethane primer the next day.... Also, it looks like you used some relatively fine sandpaper; I prefer 80 grit on bare fiberglass and spray epoxy and then regular primer over the rough 80 grit for maximum "grip" :smash:
Might be overkill but so far never had a problem with this method.....
Ok you convinced me to do a test.Spraying primer with low pressure shouldn't smell more than the fiberglass resin .... I'd give it a try but I wouldn't want to piss off the neighbors either.....
Thank you so much Karstern.I've used PPG DP epoxy, awesome stuff but expensive. Recently I used SPI epoxy and WOW..... Now that stuff is great, it is even sandable (not reduced) unlike many other epoxies. If you reduce it you get a sealer that it not sandable.... Www.southernpolyurethanes.com
They have great high build urethane primer too.
I also like the PPG shopline urethane primer, but the SPI stuff is easier to order.... For that shopline stuff I have to drive across town and they don't sell online and don't ship....
Thank 427swede. That's appreciated, coming from you it's an honor given the quality of your work.Always looking forward to your project updates, nice work! It is something special about a car that is beeing prepared for paint, a promise of things to come:thumbs:
Perhaps you should let your new weather stripping sit still for a few days with the doors closed so it sets itself a bit?
Talk about funky smells, I tell you this is a true story.....
I was living on the second floor of a high rise, and the parking lot was right below my apartment, all I had to do was drop a cord out the door/balcony and work on a 14' sailboat, I put new mahogany rails on it, painted the hull but noticed the core of the hull was made of stupid balsa wood....which of course soaked up water, so not only heavy as hell, but affected hull integrity....soft floor....so out with the tools and cut out the inner hull, and remove all the rotten wood, so in with styrofoam, layer of cloth and epoxy.....then to put a layer of glass roving and heavy with Fiberglass resin, which of course stunk to holy hell, it was parked not so very far from the main air intake for the entire 500 unit building, so the smell of fiberglass resin went though the entire building and stayed noticeable for a WEEK......stunk people out, headaches, etc.....mgmt was nice to me over that one, BUT...:smash::smash::surrender:
Why the hell do I have no difficulties believing you?
Gene -
In today's world - Obozo's EPA would have you in court and "aggressively prosecute!"
