Plastic Fantastic 2
Today's news, no pictures. I sent the wheels back to Apex. To trade them for a wider front and a 19" rear. I really wanted the 18s around it but they simply don't have the tire selection available now.... The fronts, I didn't like the offset so basically I'm using a rear "stock Corvette" dimension for the front - which will give me a 295 front tire and 325 rear. Will still need to modify the front flares but not as drastic - add 1/2" or so per side.
Next up, install the gears, port EFI and new sidepipes. along with everything else I'm doing. Will be a busy off-season but hopefully next year I'll meet my goal of being competitive....
and, I was 'competitive' this year and did pretty well for a wet-behind-the-ears-rookie. What I did do this year was make some really good acquaintances who are really helping behind the scenes....
and I smile at the thought that it seems just yesterday (10 years ago) that I was arguing with a german on here about cars.... thanks for putting up with me, your help has been invaluable.
boxes
winning
basically, I'm using rears from a basic C6 on the front and a GS C6 on the rear
11" fronts, they 'just' clear on the inside on the upper control arm
I may have to do some work on the front flares to make it perfect but I can run it like this... we will see once I put the 295s on the front... I'm stoked. Next up is the headers and port efi....time to make this fast...
more updates, the much anticipated Global West suspension upgrades arrived.... why did I wait when I could have paid less for others? well, glad you asked
this changes how you adjust the front suspension - it also allows you to narrow the track by 1/2", a real benefit if you're already considering whether or not you will have to reflare the car to fit better front tires.
But I digress, these are the upper bushings, they're basically lubeable heims
also the way they go together makes it impossible for the upper control arm to move fore and aft (which they can in the stock setup)
they also allow you to adjust camber by simply flipping the bit that bolts to the frame (the flats are ground off center)
they also eliminate the lower control arm cams (and replace the bushings with a lubeable delrin bushing)
to remind, last time out, I pushed hard enough on the 340 tread wear tires to change the camber... and now I'm going 200 tread wear and 1" per side wider contact patch
first step,
picture for posterity
push out the upper bushings
then realize I don't have green threadlock
so take pictures of 7 month old, 87 lb bloodhound puppy and her sidekick, Luigi
easiest way to get the upper ball joint off
drill and tap for grease zerts
upper assembled
and installed
and then onto the lower control arms
so I remember where it was set (it doesn't set on the lower control arm when this is done but this helps me align it later
remove bushings
bushings removed
no more rubber, delrin
nicely machined so they get fully lubed
a 'while I'm there' shaving just a bit off the new sway bar gives me clearance I need
I really like the quality of the Global West parts.
Had to build a gate so got delayed on working on the car
hard to believe it's $1600 if someone else builds it for you
In other news... mounted the tires to the track wheels, I'll have to weight them, they're substantially lighter
the rears are the same size as what's already on there but the fronts
275/35zr18 v. 295/30zr18 - so shorter and wider.... but I think the same offset so, crossing fingers, no need to cut the flares and widen them
anyway, got onto the car - should have taken more pictures
and hit a slight snag.... I need it to go into the innermost 'spot' but something is preventing that from happening...
so I'll take it apart again and see what's up....
and the new rear end is ready to be picked up
to be continued....
to remind... these weren't fitting
they do now
the problem (basically a burr)
after a bit of love with a die grinder
ages ago I bought dies to port heads, I may have used them once for that but they are handy for things like this
much much better
with the new wheels on it
and they fit!!!! 1" wider tire - these rims - well all the rims are for the back tires of a C6. The front are stock C6, the rear are GS C6
these fit better then the GS wheels which are 1 1/2 inches narrower
tire/wheel weights
stock GS front
race GS about 4lb savings per wheel - granted, it's also a wider tire....
rear GS stock wheels
the most amazing, 10 lbs savings on each rear wheel
tomorrow
That's a serious footprint! With the new shoes and the Del-A-Lum bushings it should be really interesting to see how the car responds to your inputs and changes your track times.
didn't get much time to work on it today, however, did get to checking the alignment.... 6* castor, 1.5 camber. great for a street car, I can flip the shims on the lower control arm to gain 1 degree of camber - which is about perfect for an autox
I'll take it
I should use dzus fasteners to install this.... what is this, rear diff number 3?
bright side is if I do the Silver State Challenge, I have the rear diff with the right gears as spare
yay practice
nothing left to do but to do it
my 'stock' C3 rear suspension :)
old ready to drop
empty hole
getting back together
oil is in it, tomorrow I'll tighten everything back up - I also want the rear up about an inch...
the 'to do' list:
replace inside mirror with one that doesn't move
oil catch can
do something about the center console - it's dropped and now is hit by the shifter
put it away - then collect parts for the port EFI, better headers and maybe build a spare motor.
and back on the ground.... I may have tightened the rear coil overs a bit too much but past experience says drive it a few times
I ordered a very cheap set of 304 stainless 16g shorty headers.... next up is build new headers. I also ordered a port efi intake manifold. I'm going to assemble it myself. I don't trust FiTech and the Holley does give enough fuel at full song.
With that said, I may put this in its box after putting a solid heat cycle or two in the differential (and reset the speedo)
note, when adjusting the e-brake, be sure you put the handle down before you do so. Ah well, I wanted to put it up on the lift again... well, no I didn't, but I get to anyway.
with that said, this drives amazing. Next weekend is a local autox, the last of the season, this should be fun.
